20 Most Recent
Sony DAV-S880 System Questions & Answers
Why is it not turning on?
The answer to this maybe the fan at the back is either blocked with a build up of dust or has to be replaced, I had the same problem and took it out to be repaired started to wipe it down and thought would give it a go after this and it kicked back into life. Hope this works for you. John
I have a sony dav-s880
Sorry to inform you that you have to replace the DVD optical unit ( lens assembly ) .Will cost you about 20$ plus labor. Will need professional help to replace.
Hi, I have the DAV-S880, and with powering on, the
The answer to this maybe the fan at the back is either blocked with a build up of dust ar has to be replaced, I had the same problem and took it out to be repaired started to wipe it down and thought would give it a go after this and it kicked back into life. Hope this works for you. John
