20 Most Recent
Sony DAV-DX375 System Questions & Answers
IT DISPLAYS PROTECTOR PUSH POWER
its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Dav-dz30
Sounds like unit is in protect mode. This is usually caused by a problem in the amplifier section. Only way to fix is to replace the main board - hope it's under warranty, otherwise it's probably not worth fixing
DX375 plays in black and white only
Turn On unit, make sure there is no disc inside, press Display on remote and go to Settings menu, select RESET all and press Enter.
Turn Off unit for minute, turn it On and load disc and press Play and check picture, if still no colors in picture, check your tv by hooking another video source in same input and confirm it gives color picture.
If tv found OK then its home theater system defect and it got problem in signal output section, now it is hardware issue and qualified tech will fix it by checking its circuit.
Thanks.
Will not read DVD (old or new)
Run a "Laser Lens cleaner" thru it several times, preferrably one which uses fluid. You can purchase them just about anywhere for under $20. Beyond that, it would have to be serviced, and they will replace the transport. Usually $150-$200 Hope this helps
DVDs won't play
Even though the CD plays fine I will still recommend you to run a disc cleaner on that player, to make sure that the lens are clean....
Dvd movies
sounds like you have hooked up your system with a component cable these must be wired red 2red green2green blue2blue and this output set on your system and selected on your tv.if you have done this and your cables are ok you may have a fault in your system or tv.
hope this is helpful.
cable guy.
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
