20 Most Recent
Compaq IDE CD-Rom Drive Presario 500 (177072001) Questions & Answers
CD Driver not work
When you said CD driver are you referring to the Compact Disk which contains data of the drivers for your computer?
If that cannot be recognized by your computer you can always go to the website of your computer manufacturer and download the drivers that you need.
OR
Are you referring to the cd drive of your machine?
If you are what's exactly happening? does it not recognize a certain CD or anything you put in cannot be recognized?
My presario 500 wont even turn on
try running it in safemode and if you have recently added any new hardware or software that may be causing your problem uninstall it while you are in safemode.
As the computer boots press F8 to enter safe mode. If this is successful then everything on the screen will look big, ignore that for now. uninstall anything that may be causing the problem. If you have not loaded anything lately, then while in safe mode restore your computer to an earlier date when you know that everything was working okay.
You can do this by going to Start>all programs>accessories>system tools>system restore. Then choose a date when you know that things were okay and press restore. You computer will restore to the date you selected and it will reboot. If asked to whether you want to start windows normally after the boot then select that option.
I hope this helps
How do i fix a presario 500
Go with safe mode ( with F5 OR F8 key) and go START -RUN then type ms config then go to STARTUP and desable all ( just don't desable antivirus) APPLY + RESTART!
Let me know if you'r problem is fixed and rate me as FIXYA!
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
