20 Most Recent Panasonic SC-HT740 System Questions & Answers
I have problem with my home cinema Panasonic home
Hi this error comes when you keep your device powered all the time. Definition: power is constant to components always on so it heats up. look for condensers that are popped up or seems to be change it with same type and voltage Description of Error Code. F61 State, Condition When the power is turned on, the unit is automatically turned off. The power does not turn on. ยท Cause, Troubleshooting Power circuit system failure and/or direct current flown to speaker terminal Good Luck
11/19/2017 10:16:29 PM • Panasonic... • Answered on Nov 19, 2017
10answers
Panasonic SA-HT740
I had the same problem it took four or five e-mails to find the fans
I found them at the site below
www.pstc.panasonic.com/Epartr/PartsDone.asp
P/N. L6FAJCCH0007 FAN MOTOR (THIS IS THE REAR FAN)
P/N. L6FAYYH0001 FAN UNIT (THIS IS THE SIDE FAN)
Hope this helps
Scott
2/24/2017 3:28:54 PM • Panasonic... • Answered on Feb 24, 2017
2answers
DVD HO1 error, and tray is jammed - how do i change the mode to External Port (iPod)?
It means that there's a misaligned disk inside. You need to
1. Unplug it and shake it side-to-side.
2. Then turn it on and press the open/close.
3. If it doesn't open, goto step 1.
4. When it opens, get the disks out, use disk exchange to try to get them all out.
5. Turn it off, unplug it, shake it again and make sure that there isn't another loose disk, if there is, then open it and get it out.
This is a known flaw in certain Panasonic DVD changers. Good luck
-Senrich
12/4/2015 10:50:57 PM • Panasonic... • Answered on Dec 04, 2015
0answers
0answers
2answers
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
[email protected]
10/17/2013 5:02:46 PM • Panasonic... • Answered on Oct 17, 2013
2answers
"Panasonic SA-HT640" Code F61
Check to make sure Fan is turning at full speed
if not, replace fan
3/13/2013 8:59:11 PM • Panasonic... • Answered on Mar 13, 2013
0answers
Playing black and white
check your hook ups look in your manual
10/6/2012 8:40:02 PM • Panasonic... • Answered on Oct 06, 2012
0answers
SA-HT740 DVD H01
Be the first to answer 1/14/2012 2:25:13 AM • Panasonic... • Posted on Jan 14, 2012Be the first to answer
Tray stuck in out position and husing as Audio amplifier
If your system has an Aux input on the back then you can use it as an amplifier, and use the speakers you already have. I hope this gives you some ideas.
12/22/2011 6:37:58 PM • Panasonic... • Answered on Dec 22, 2011
F61 error
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
7/22/2011 11:54:54 PM • Panasonic... • Answered on Jul 22, 2011
Dvd player will not play
Page 12 of the manual...
Just the CD discussion. DVD is above it on page 12...
CD [CD] [WMA] [MP3] [JPEG] [VCD]
≥This unit can play CD-R/RW recorded with the above formats. Close the sessions or finalize §2 the disc after recording.
≥ [CD] This unit is compatible with HDCD, but does not support the Peak Extend function (a function which expands the
dynamic range of high-level signals).
HDCD-encoded CDs sound better because they are encoded with 20 bits, as compared with 16 bits for all other CDs.
≥ [WMA] [MP3] [JPEG] This unit also plays HighMAT discs.
≥[WMA] This unit does not support Multiple Bit Rate (MBR: a file that contains the same content encoded at several
different bit rates).
§1 Includes single-sided, dual-layer discs.
§2 A process that allows play on compatible equipment.
≥ It may not be possible to play all the above-mentioned discs in some cases due to the type of disc or condition of the recording.
Discs that cannot be played
DVD-RW version 1.0, DVD-ROM, CD-ROM, CDV, CD-G, SACD,
DivX Video Discs and Photo CD, DVD-RAM that cannot be removed
from their cartridge, 2.6-GB and 5.2-GB DVD-RAM, and "Chaoji
VCD" available on the market including CVD, DVCD and SVCD that
do not conform to IEC62107.
2/2/2011 3:43:15 PM • Panasonic... • Answered on Feb 02, 2011
Panasonic SC-HT740 System Logo
56 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
panasonic sa ht740
  • Audio Players & Recorders
