20 Most Recent Kenmore 62642 / 62644 / 62649 Microwave Oven Questions & Answers
How to install turntable motor in kenmore 72169072900
You can find helpful exploded views and find parts by entering your full model number (72169072900) at the Sears Parts Direct Web site.Remove the glass tray and turn the oven on it side to get to the bottom base plate.If you look at the diagram titled "base plate parts" you'll see the access panel on the bottom in the center that has to be removed to get to the turntable motor screws.On some models, you have to cut the metal strips holding the panel in place, then during reassembly use a screw to reattach it. In some cases, the cover has to be rotate 180 degrees before reinstallation.You then unplug the connectors on the turntable wires, then remove the screws holding the turntable motor, gently lift it out and also ease the turntable off the motor shaft.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
1/30/2013 3:42:53 AM • Kenmore 62642 /... • Answered on Jan 30, 2013
Microwave works but stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
7/29/2011 4:31:14 AM • Kenmore 62642 /... • Answered on Jul 29, 2011
The oven makes a loud humming noise when turned
This is most likely a bad magnetron, but it could also be a bad high voltage diode.
I would check out this website
http://www.applianceaid.com/micro.html
Or you could call a local Appliance Repair Technician
12/10/2010 1:24:51 AM • Kenmore 62642 /... • Answered on Dec 10, 2010
2answers
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
6/1/2010 3:44:05 PM • Kenmore 62642 /... • Answered on Jun 01, 2010
Turntable turns on automatically when i close the
It's most likely a bad door switch or mount. See this file for help on diagnosing, ordering and replacing door switches.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
5/28/2010 12:39:43 PM • Kenmore 62642 /... • Answered on May 28, 2010
How do you un-install a kenmore 665.61639100 microwave?
the link below will take you to the installation instructions if needed.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0211226.pdf
12/27/2009 12:45:38 PM • Kenmore 62642 /... • Answered on Dec 27, 2009
I've got a Kenmore microwave that just stopped
If the oven is completely dead, (no light or display) it probally is a fuse problem. It does have a 20 Amp fuse. With that being said, I would stress that a qualified service technician check it out. There are some high voltage components inside and a person who is unfamilar with high voltage components can seriously get hurt or even die if they don't take the proper precautions working with this type of appliance.
12/24/2009 4:45:27 AM • Kenmore 62642 /... • Answered on Dec 24, 2009
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
11/9/2009 2:07:55 AM • Kenmore 62642 /... • Answered on Nov 09, 2009
Microwave oven fan will turn itself on and off
It may be a shorting pad (the hood / vent fan pad) on the keypad or a part on the control board.
Absolutely - If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
If you need a new keypad, that would add about $37 to that cost.
Feel free to visit our Web site or contact me directly with your model number and symptoms.
William E. Miller
[email protected]
http://www.microwavedisplay.com
10/11/2009 7:37:52 PM • Kenmore 62642 /... • Answered on Oct 11, 2009
Kenmore microwave
I had this problem before. Look on the display. Is there a little 'd' on there? I can't find my manual, but inside it shows you the combination of buttons to push on the display to fix this. Anybody else know the secret combination? What the heck does the "d" stand for anyway?
1/15/2009 1:35:54 PM • Kenmore 62642 /... • Answered on Jan 15, 2009
6answers
Runs but makes a super load pop sound with flame
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
12/29/2008 8:47:42 PM • Kenmore 62642 /... • Answered on Dec 29, 2008
Troubleshoot why light underneath doesn't work on kenmore 62644 microhood
We see this a lot. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
11/19/2008 4:55:43 PM • Kenmore 62642 /... • Answered on Nov 19, 2008
Part number for underneath light controller
We see (and repair) this a lot. The problem is on the control panel assembly, which we regularly repair nationwide by mail for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
[email protected]
10/20/2008 3:28:50 PM • Kenmore 62642 /... • Answered on Oct 20, 2008
2answers
Kenmore over the counter microwave problem
It has a bad relay on the control board. The board will need to be replaced.
10/3/2008 6:35:34 PM • Kenmore 62642 /... • Answered on Oct 03, 2008
Kenmore 62642 / 62644 / 62649 Microwave Oven Logo
38 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
turntable turns automatically when close
  • Microwave Ovens
