20 Most Recent
Dell PowerEdge SC1420 (SC1420MIN) Server Questions & Answers
Poweredge SC 1420 won't come
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
After a power outage our
bad battery in mother board it looks just like a watch battery if this isnt the case your power box is burnt you will have to replace the hole power box.
Start the server error inthe o/i
All Dell servers come with lifetime phone support.
Call Dell and they will help you identify the problem and provide solutions.
I think the number is (800) 945-3355.
You will need the service tag number from the server chassis.
If this helps, please vote for my solution.
Dell Poweredge SC1420 won't boot up
Amber lights are typically bad.
Good news, Dell has lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis and call Dell.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Dell Poweredge sc1420 and novell
Hello Moshe88,
Can you give me your server's Service Tag please, so I can get a look at the hardware spec of the system please?
I'll then be able to assist further.
Thanks
reaxion
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
