20 Most Recent
Lanier Compatible Copier Toner Black For 6112 Questions & Answers
Error codes SC389and SC377 keep occurring and shut
All printers are not equal. Some utilize cartridges with ink reservoirs and print heads all in one. Some only have a Separate Print head carrier with a main print head and slots for ink-filled reservoirs. You can purchase and use less expensive cartridges from on line vendors. If you elect to refill carts, be prepared for a messy venture. What many printer users fail to recognize, is the print heads do wear out and prior to complete failure, the heads either cause streaking or poor color density. To clean a print head, run under the tap for a few minutes, very hot water on both sides , metal bars and where the ink enters. When all signs of ink have vanished, replace in the printer. Do not touch metal contacts as oil will interrupt electrical communications. Do a printer test and alignment. Should work.
