20 Most Recent Konica Minolta Konica Kit For Bizhub Press C7000 350k And C6000 300k Dadupm3500 Questions & Answers
This going to take a while, open both front doors do not pull out the lower section your, going to pull out the upper middle section. then from the right side (WHAT EVER YOU DO NOT LEAN / HOLD ANY ONE OF THOSE FOUR SHAFTS!!!!!!!!!!!!!!! THAT WILL CAUSE MAJOR TROUBLE! Now reach in and you will see a small assy. which is across from the transfer belt on the other side of the unit you just pulled out. On the assy. are three sensors each covered by a metal cover with a dry rag ensure no static electric can destroy the sensors. clean all three, be careful each has a small spring do not let them fall inside the machine. If you want to or have to remove that assy. there are two screws and once connector all the way in the back (DO NOT LEAN ON THOSE SHAFTS!!!!!!!!!!!) don't let the screws drop! Once done remove the transfer belt, and clean the transfer belt cleaning blade system, then run gamma, and color checks in 36 Mode. GOT IT! Better have a tech come out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 10, 2018
check the yellow drum unit
Konica Minolta... | Answered on Jul 04, 2016
what model number
Konica Minolta... | Answered on Jul 03, 2016
Hard drive failure or not connected
Konica Minolta... | Answered on Jun 25, 2016
2813...related to cyan.
Excess charge on drum beyond the specified value.
Solutions...1) swap the drps board with yellow or with other color unit and see weather code is changing .if it is changing the drps board is the culprit.
2) clean the HV contacts located behind the processor unit.
3)clean the IDC Sensor unit
4)change developer
5)caronas
Konica Minolta... | Answered on Jun 24, 2016
replace it
Konica Minolta... | Answered on Jan 18, 2016
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Could be one of these, start first with the Y drum
Anything else get a tech out power supplies and printer control boards are serious money$$$$$$$$$$$$$$$
• Printer control board
(PRCB)
• Drum motor /Y (M14)
• Encoder sensor /Y1
(PS81), /Y2 (PS82)
• DC power supply /2
(DCPS2)
• Drum Unit /Y
Konica Minolta... | Answered on Jan 10, 2016
Try cleaning the corona wire housing by disassembling it and washing it with dish washing liquid, or replace it with new. or maybe you got the wrong corona wire. or maybe try to install it the right tightness.
Konica Minolta... | Answered on Apr 17, 2013
Enter in the service mode and select counter mode and reset a counter to selected parts.
Konica Minolta... | Answered on Apr 07, 2013
Maximum density correction problem.Clean the AIDC sensor located under OPC drum.
Konica Minolta... | Answered on Mar 20, 2013
How to replace fusing unit in c253
Konica Minolta... | Answered on Jul 13, 2019
What do you want to reset???
Konica Minolta... | Answered on Jul 08, 2019
Konica Minolta Konica Kit For Bizhub Press C7000 350k And C6000 300k Dadupm3500 Logo
15 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
codigo de error
  • Office Equipment & Supplies
