20 Most Recent
Savin Lanier Ld275c Lp138c C7570 4 Drum Set b,y,c,m Questions & Answers
SAVIN C7570 BLACK INK PRINTS FADED (INCONSISTENT)
Hi Linda
Is this ink or toner? Ink will expire if it is on a shelf too long. Toner is a powder that is applied with heat to the paper. It does not expire but will appear faded if the printer is in economy mode or low on toner. on a 4 drum system each drum is independent of the others and can run low or out at separate times. Therefor to save money only replace the empty drums. Have you changed the drum recently? If it is toner try removing it and shaking it, then reinsert it. If you have other boxes of this drum see if you can find a date on the box. ink over three years old may not work well.
Savin 917 Copies are faded on the Left side of page.
Kenneth:
I would remove and cover the drum carriage (to protect the drum from damage by exposure to light), and check and clean the corona wires. There is a charge corona and a transfer corona, so that's two coronas that you'll have to clean. If you can remove the coronas from the machine, you can do a better job of cleaning the coronas. A faded line down the page like you're getting could be a paper shard stuck to one of the coronas... it's been known to happen.
What means Service call code SC565 on a savin C3030 printer?
That code is most likly fuser code, could be blown fuse, or fuser may have to be reset by getting into service mode, Yellow key 107 red key, now in svc mode. look for tab that says mode. depress and look for code to reset fuse coul be 5810 and depress excute. turn on off that should reset fuser if code comes back you have bad fuser, fuser, lamp etc.
