20 Most Recent
Sony RM-Y173 Remote Control Questions & Answers
Code for panasonic
This remote is designed to control the product that it originally came with. If the remote has buttons for other product types (TV, DVD, etc.), it can control only Sony branded versions of these products. It is not a univeral controller.
Sorry
TENGO CONTROL REMOTO RM-Y173 Y NO TENGO EL CODIGO
El RM-Y173 teledirigido no es programable y los códigos alejados no se
requieren.
Este telecontrol se diseña para controlar el producto con el cual vino
originalmente. Si el telecontrol tiene botones para otros tipos de
producto (TV, DVD, etc.), puede controlar solamente Sony calificado las
versiones de estos productos. Observe por favor que este telecontrol
puede no poder controlar todos los modelos de estos otros tipos de
producto de Sony.
Certain buttons wont respond
I had a Sony remote that got dropped. Looked inside and found the circuit board broken. The ideal solution is to by a direct replacement--expensive. I had an amplifier remote with learning and lots of buttons. The cheapest ($10-$15) is to buy a universal remote, hopefully with a learning function in case you need to get more that just the numbers, volume, mute, and up/down. They may not know how to change source, TV/VCR, menu, etc. Most will know how to do Sony while many will not know off brands.
-Ken
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
