20 Most Recent
Sony RM-Y180 Remote Control Questions & Answers
How do i program a sony remote model # 4-978-977 to a digital stream converter box
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window " to get gathered related posts.
Sony rm y186 remote
Sounds like the circuit track inside the remote control [at its PCB]; had opened. An open circuit can cause this fault. In most cases, this fault can be repaired. Contact any service technician. The remote control has to be opened.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
I have a problem with
this site will help you :http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMY180#. However this remote will operate only Sony TVs, so there are no instructions to program otherwise. Did you try pressing the TV button on the remote and/or changing the batteries?
Code for optoma tv
if you dont have a manual for your remote you can prob download one from sonys web page if its not in there just call the assistance number and they will have one that will prob work.
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
