20 Most Recent
Salton ICM15 BIG CHILL 1.5 Quart Ice Cream Maker Questions & Answers
Salton hand crank big chill ice cream maker
I bought one new, and it had a great recipe for Kiwi fruit ice cream, using kiwi fruit and oranges. I can't find the recipe book. You make just over 1 l of fluid ice cream mixture, the bowl must be pre=frozen for at least 15 hours, just put the liquid in the machine and crank the handle in quarter turns (the square outer box helps measure this!) every 5 min for the first 30 min, and then half turns every half hour or so.
Ice cream won't set up
The ice machine is a little more complicated then what it look like first you need to know if is any air filter. should be there, some where if no air filter do not try to fix the machine your self this type of equipment contains refrigerant and high voltage should be handle by an experienced certain devices hold electrical charges even unplug hope this is usefully.qualified technician may little but could be dangerous
Replacement lids for Salton Jars
I don't know the exact size you need, but for that kind of thing I go to Uline. They seem to have almost everything that no one else does. Their minimum order may be more than you want, though.
http://www.uline.com/
I need a operational manual.
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
OmomI have a Salton ice
The fan should run.Check if the fan is getting blocked by anything or the fan motor is got shorted.Check the fan motor connection to main board.If the motor is heating but fan not running, then its faulty motor.------- This should help. checkout.Keep updated.Thanks.Helpmech.
