20 Most Recent
Jensen JER-822 Remote Control Questions & Answers
RCA codes
Check these codes. 10000, 11447, 10051, 10093, 10679, 11047, 11147,
11247, 11347, 11781, 12002, 12187 If you wish to get more,
http://remotesearch.blogspot.com/
I have the jensen remote
Jensen's website has the codes. If you can give me the model number of the remote as well as the brand name and model number of what you are programming it to, I can probably help with that as well.
Davis DL X10 projector remote control codes
Go to : http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=devices&br=davis&dv=projector&md=dlx10&kw=davis&st=&ar=&dt=&so=&pg=1&file=ccf_templates/complete_system/dj_ccf.zip
File for Philips Pronto Remote control, but could be converted to others remotes.
CODE FOR PANASONIC TV'S I HAVE A JER 323
Guys it's really easy just press on-off and tv at the same time, until de on-off botton turns on. Point the Remote at the TV DVD or SAt and press it 3 sec max. until the tv turns off. then press the stop button and that's it...
Cant remember parental codes and need to disable
If you are referring to parental codes that you entered for your cable or satellite box, the best way to solve that issue is to either perform a factory reset on the box, or call your cable/satellite provider and tell them your problem. They can do a reset from their end once you've proven to them that you are the registerd owner/user of the equipment.
Programing problems
to program with codes hold device butoon while entering the 4 digit code, manual press and hold device and on/off button til light comes on, press on/off every 2 secs or so til it turns off device, then press stop to save code. i have code list for jensen jer 422 remote if you need codes email me at
[email protected]
Locateowners manual/program codes for tv remote
Codes for Zenith T.V are 1000,1001,1004,1083,1101,1100,1099,1097,1089,1078,1022,1020,1011,1009
Jensen 422
I have a JVC tv and need to know how to program the remote control
JER 323
Without the code on JER-323: 1. Press the device
button - example - "TV" and the power button for 3 seconds until the on/off
button stays lit. 2. Once the on/off button is lit, press the on/off
button until t ...morehe unit turns off. 3. When the code is located, press the stop button at the bottom to save the code.
