20 Most Recent Sylvania 6260VF VCR Questions & Answers
Old tapes recorded wont track speedup slow down
Hello; This can be a very complicated issue. The simplest, is a dirty control track head located on the output (or right side of the drum containing the video heads). It is just before the pinch roller. Clean well with isopropyl alcohol 91%. The second likely thing is a damaged tape, that has a creased bottom edge caused by a defective VCR that has excessive reel takeup torque that causes this tape to crease while playing it. Open the cassette door where the problem is and check the tape for a bottom crease. usually about a crease 1/32 of an inch or more from the bottom. Tapes that are creased cannot be saved. John
12/15/2010 7:02:19 PM • Sylvania 6260VF... • Answered on Dec 15, 2010
How do i adjust tracking. tapes roll. used a
Cleaning tapes are not as good as going in with a can of Servisol Video 40 and some cotton buds. Take the top cover off and give it a really good clean with them. Clean everywhere the tape touches. Make certain you allow to dry before trying again. If that doesn't work you could have a faulty head.
PS it will take longer to clean if it is housed in a room where people smoke!
10/1/2010 3:40:47 PM • Sylvania 6260VF... • Answered on Oct 01, 2010
Get nothing but static when i turn it on
make sure you go from the cable box were it says out to the in on the vcr from the vcr you want to come out to the tvnow you can program the the vcr to pick up the cable chanell from the boxthe vcr has to be on chaell 3-4 in the front were it shows what chanell your on then the tv and the vcr are to be on the wright cahells the tv has to line up with the chaell your useing for the vcr3-4 to make this less complicated put a tape in the vcr hit play if its playing you are on the right chanel you do not have to have the vcr to watch cable it will go threw even if vcr is off just have to be right chanel
5/18/2010 4:33:25 AM • Sylvania 6260VF... • Answered on May 18, 2010
Clock will not keep time
Aside from resetting the time to the correct time every once in a while, it's not worth fixing. I have a sharp vcr that the clock starts to run fast 2-4 weeks after i set it.
And another thing to check is to make sure the VCR is not plugged into a socket that activates with a wall switch that you might turn on and off everyday.
4/10/2010 7:14:21 PM • Sylvania 6260VF... • Answered on Apr 10, 2010
Tracking
A CONSTANT streak anywhere on the screen could be a scratch in the tape itself. Losing sound, and ocassionally everything going to black and white, sounds like a dirty control track head.(The audio and control track are in the SAME head (a 3/4" metal cube that the videotape travels on). The control track section is on the upper part, and the audio on on the lower part.
If the control track head's dirty I'm sure the rotary head's dirty too! Losing audio and have tracking problems, point to dirt. And you MAY have SO much dirt built up on that head it's scatching your tapes (unrepairable), and causing you problems. Make sense?
3/16/2008 2:57:14 AM • Sylvania 6260VF... • Answered on Mar 16, 2008
Tracking
Does this happen on ALL tapes?
Depending on WHICH model VCR you have (old or new) SOME have a switch which will allow you to adjust tracking MANUALLY. When the switch is in the manual position, it won't track automatically. If some played with that switch, that could cause your problem.
ALSO, do you have a cleaning tape? If the control track head is dirty, it won't see the "control track" (which gives you VCR information to control the tracking.
Another possibility is one of the video heads (there's 2 or 4) is dirty, and without ENOUGH video signal coming off the heads, it's not possible to track properly.
Try running a cleaning tape through. If you've never done it, it might be time. Unless yu know about equipment I'd wouldn't suggest you open the machine and clean it yourself. Let me know how you make out.
3/16/2008 2:05:09 AM • Sylvania 6260VF... • Answered on Mar 16, 2008
Is it possible to cast/mirror/ etc. from ab android phone to a Sylvania TV manufactured in 2005?
No, because screen casting wasn't invented and it isn't a Smart television. Time for a new one.
3/11/2024 8:53:32 PM • Sylvania... • Answered on Mar 11, 2024
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work. Let's troubleshoot the issue and try to get it working: If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why. Check Power Cord and Connections: First, ensure that the power cord is securely plugged into both the TV and the electrical outlet. If you suspect a faulty power cord, consider trying a different one. Reset the TV: While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset: Unplug the TV's AC adapter from the electrical socket. Press and hold the Power button on the TV for 20 seconds. Plug the AC adapter back in and turn on the TV. Check Audio/Video Cables: Inspect the audio/video cables connecting your TV to the satellite or cable receiver. Ensure that the color-coded prongs match their respective connecting points. Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs. Inspect Coaxial Cable: Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN. Confirm that the connection is firm; a loose coaxial connection can cause display issues. Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure. Check for Interference: If distortion continues on the TV screen, consider nearby interference. Power-hungry appliances can cause electronic interference, affecting display quality. Visit a Repair Shop: If the above steps don't resolve the issue, you may need professional help. Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering. If uncomfortable with such tasks, consider visiting a repair shop
2/3/2024 6:17:20 AM • Sylvania... • Answered on Feb 03, 2024
2answers
I have a 37in limited edition Sylvania TV I have tried every code on my Phillips universal remote none work. Is there a specific code.
  1. Auto Code Search:
    • Turn on your Sylvania TV.
    • Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
    • Press the "TV" button on the remote to set it to control the TV.
    • Press the "Power" button repeatedly until the TV turns off.
    • Press the "OK" or "Enter" button to save the code.
  2. Manual Code Entry:
    • Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
    • Press and hold the "Code Search" button on the remote until the indicator light stays on.
    • Enter the code using the number buttons on the remote.
    • Test if the remote now controls your TV. If not, repeat the process with a different code.
  3. Try Common Codes:
    • Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
1/9/2024 10:32:14 PM • Sylvania... • Answered on Jan 09, 2024
Sylvania tv with vcr/dvd player. vcr tape keep being ejected even when using tape cleanser ejected
The most likely cause is a faulty mode switch.
12/12/2023 10:12:41 PM • Sylvania... • Answered on Dec 12, 2023
2answers
Flashing colors on Sylvania lcd TV
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
11/5/2023 2:26:58 AM • Sylvania... • Answered on Nov 05, 2023
Why no tv picture on my Sylvania #ssc092 ac/dc tv/vcr combo?
it is a very simple TV, is TV connected to cable? Here is link to manual copy and past download and save for future reference. It is very old and has CRT not LCD. https://www.manualslib.com/manual/776815/Sylvania-Sylvania-Ssc092.html#manual
10/20/2023 4:15:16 PM • Sylvania... • Answered on Oct 20, 2023
Sylvania tv screen went black last night when we hit a channel button on remote
More likely you hit the Source / Input button and lost the signal. Press it again until it comes back.
9/13/2023 4:08:17 AM • Sylvania... • Answered on Sep 13, 2023
Codes for a Sylvania 32'tv
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 4-Digit Sylvania TV Codes for Universal Remote
  • 0002.
  • 0008.
  • 0030.
  • 0054.
  • 0068.
  • 0096.
  • 0171.
  • 0321.
More items... • Jan 1, 2023
RCA Universal Remote Codes For Sylvania TV - GenTwenty
6/22/2023 5:33:00 AM • Sylvania... • Answered on Jun 22, 2023
How can I unlock my PIN# on my sylvania smart tablet, and DVD 10.1.
By typing the correct pin or activating a factory reset.
6/17/2023 8:57:49 PM • Sylvania... • Answered on Jun 17, 2023
Does sylvania LC260SS2 support earc/arc with the hdmi inputs?
The Sylvania LC260SS2 has a eArc option called fun-Link. This only works with other fun-Link compatible devices. See https://www.manualslib.com/manual/325827/Sylvania-Lc260ss2.html?page=14#manual . (Sylvania TVs are made by Funai Electric.) It may not work with non-Funai electronics. I hope this helps. Cindy Wells
4/25/2023 10:32:56 PM • Sylvania... • Answered on Apr 25, 2023
I need the codes for DVD players I have a Sylvania and the easy setup isn't working so I need the code and the hard way to set it up.
Sylvania DVD Player Remote Control Codes
codesforuniversalremotes.com https://codesforuniversalremotes.com > sylvania-dvd-p... Program your universal remote control to a Sylvania DVD player. Use the following remote codes. Sylvania DVD Player 4 Digit Remote Control Codes: 2213 2260 2321
Sylvania DVD Player Universal Remote Codes
universalremote.codes https://universalremote.codes > sylvania-dvd Feb 14, 2021 - First of all "Turn The Device On" · Now press and hold the "Setup" button · Enter the "9-9-1" (three digit) code · Now hold down the "Power Button" ...
directutor.com https://www.directutor.com > content > sylvania-dvd-p... Sylvania DVD Player Remote Control Codes ... GE Universal Remote Codes with Program Instructions. sameeha ... Smart TV Universal Remote Codes By TV Brand. ..
3/25/2023 6:17:57 PM • Sylvania... • Answered on Mar 25, 2023
Can the Sylvania LC320SLX be connected to the WiFi for streaming viewing...???
Of course not. It is an old and simple set from 2009 and perfect for a bedroom
Sylvania LC320SLX LCD TV (LC320SLX)
http://www.hdtvsolutions.com > Sylvania-LC320SLX A smart and trusted choice for everyone. The LC320SLX offers high-level video and audio entertainment in a stylish package. View high-definition programs in ... Component (HDTV): 3 RCAs Formats: 480i, 480p, 720p, 1080i Screen Size: 32" Diagonal HDMI: HDMI (3 sets)
3/7/2023 5:50:48 AM • Sylvania... • Answered on Mar 07, 2023
Televison & Video Logo
Popular Tags
10 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
tracking
  • Televison & Video
