20 Most Recent
Canon Ink Cartridge GPR15 for iR 2270, iR 2870 Questions & Answers
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
3/14/2018 4:55:22 AM •
Canon Ink...
Answered
on Mar 14, 2018
E000716-0010
The error you are giving isn't a toner error. It relates to a loss of communication with the pedestal. Canon's service manual says to check the cable leading down to the pedestal. If still properly seated, replace the DC Controller Board or Pedestal Control Board.
Reference: Canon Service Manual Page 694. You may be able to locate the manual by a Google search. Search for "Canon
iR4570/3570, 2870/2270 Series Service Manual"
9/1/2017 12:54:13 PM •
Canon Ink...
Answered
on Sep 01, 2017
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
11/2/2016 5:42:09 AM •
Canon Ink...
Answered
on Nov 02, 2016
PRESSER ROLLER CUT AFTER 20000 COPIES WHY
This is a low number for that roller.Check the bearings make sure they are not seized. If you have experience a noise then most likely you have bad bearings and the roller is not rotating correctly. The guides may have built up of toner and touching. the seperation guide plate not in correct position or knocked off .under the roller dirt and grime needs to be removed. something is touching the roller causing this and you will get better life from a OEM roller.
11/14/2015 5:39:22 PM •
Canon Ink...
Answered
on Nov 14, 2015
Ir2270 not sensing toner
Simple That problem is in the Developing Unit. If you check the DV you will find on one side it has gears remove the screws to expose the gears. Then look for the small round copper metal in front of a gear thats your culprit. Replacing it is the best way. Or clean it if no replacing part is available.
10/12/2015 11:33:46 PM •
Canon Ink...
Answered
on Oct 12, 2015
Paper pick up
Be more specific you talk about Ink cartridge problem and also paper pickup. What is the problem???????
3/7/2014 12:20:47 AM •
Canon Ink...
Answered
on Mar 07, 2014
Eror code e00732-0010
check the cable that connects the scanner to the copier bodyit sometimes gets broken you can wiggle it and reboot the devicethats the only thing that goes bad for this code
10/24/2013 8:11:58 PM •
Canon Ink...
Answered
on Oct 24, 2013
Ir2870 how to solve error 602-0102
press *(additional function) then press 2 & 8 together and *(add. fun.) again . select COPIER on screen then <function>..<clear>...<system>...<hd clear>.... switch off and after a minute start. if problem continues.... replace hard disk.
10/21/2013 7:12:59 AM •
Canon Ink...
Answered
on Oct 21, 2013
