20 Most Recent Sony FD Trinitron WEGA KD-36FS130 36" TV Questions & Answers
Hello, Welcome to Fixya.com
If the mute is ok, you want to check if your have a cable or sat box that the mute on those are ok as well, if so then your looking at a internal issue with the TV that would involve repair.
Try this
1. unplug the tv wait 10-15 seconds then plug it back into the wall outlet.
Also
2. unplug any cable boxes or sat boxes that might be causing the issue.
If you still are having issues you might want to check it into a local repair shop near you, but take this advice for what its worth you might wind up paying more for the repair then the purchase of a nice flat panel.
Make sure if you do take it into a shop that there registered with the BBB and do not have complaints registered as those shops could end you paying more money.
Thanks for making Fixya your first choice, We can Fix most things but have solutions for everything.
Regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sony FD... | Answered on Oct 06, 2013
Check and replace its CRT base socket.
Sony FD... | Answered on Sep 16, 2013
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Sony FD... | Answered on May 08, 2013
Hello
There is some sort of indirect short inside your TV. It is in the main circuit board. Most of this kind of fault in Sony Tvs are related with horizontal output stage. You just replace the horizontal output transitor [which drives the Line Output Transformer] of your TV first. If the transitor is leaky, the above said falult may occur. If it doesn't help Line Output Trnasformer [LOT] may need replacement. Check whether the replaced transistor overheats within seconds or minutes. If it overheats the LOT is faulty. Ok.
Sony FD... | Answered on Apr 15, 2013
Will you please provide more details> Is the line across the screen at its middle?
Sony FD... | Answered on Jan 03, 2013
There are two adjustments for the guns on those old tube type sets.
Sony FD... | Answered on Oct 10, 2012
Fault is with the horizontal phasing. Contact any experienced service technician. This is not a user reparable fault. A skilled work indeed.
Sony FD... | Answered on Aug 31, 2012
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Sony FD... | Answered on Aug 22, 2012
Check for it at its main power supply regulator section.
Sony FD... | Answered on Jul 16, 2012
Check the fuse inside and then have some qualified tech give you an estimate (heavy TV set).
Sony FD... | Answered on Apr 18, 2012
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Sony FD... | Answered on Feb 01, 2012
From your description the flyback transformer has failed causing the high voltage to load down, if the TV is 10 years old or more, consideration should be given investing in a new set.
Sony FD... | Answered on Jun 22, 2011
try operatingguides.com
Sony FD... | Answered on Jun 21, 2011
I'm getting the same thing - I've had my Wega for about 10 years now...I wouldn't expect this thing to be crapping out already given how much I paid for it back in the day.
Bottom line, I haven't figured out how to get rid of the random text characters...we joke and say that the Chinese are hacking our TV again.
Sony FD... | Answered on Jan 13, 2011
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
85 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
when put tv
  • Televison & Video
