20 Most Recent
Dell W3706MH 37 in. LCD HDTV Questions & Answers
Have two gray spot's on sceen
Look on power supply board for Bad capacitors they will be vented,swollen ,or puffed up on Top 1000uf 16v 220uf 10v 3300uf 10v 330uf 10v also Google to Encompass Parts and type in your model number to see if they are listing Parts and service manual for this model and another Place to Look for Parts is EBay look under Electronics TV/Parts
THER ARE 4 BOLTS TO
okay
its 75MM
vesa compatible bolts for this display now you can get a kit with the bolts and the
vesa kit to mount this the kit comes with 75mm and 100mm bolts
respectively.
I sure this will help please do click the accept button for my efforts. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Replacement remote
go to the following link and leave your model number of your set and they will contact you by email right away and let you know if they have it at their warehouse as they dont list all the remotes that they have. Heres the link.
http://servicemanuals.vstore.ca/
Dell tv 37 inch tv
My Dish Network remotes work on this TV using one of the Phillips TV codes- as Phillips makes this TV for Dell.
My Hanspree SC24LMUB has been working as a monitor for my my Dell spx 13 for years, but upon returning from a trip, it now will not connect.
I'm sorry to hear that you're having issues with your Hanspree SC24LMUB monitor. There could be several reasons why it's not connecting to your Dell laptop. Here are a few things you can try to troubleshoot the issue:
- Make sure that the HDMI cable is securely connected to both the monitor and the laptop.
- Check that the HDMI port on the laptop and the monitor are not damaged.
- Try a different HDMI cable to see if the issue is with the cable itself.
- Check the display settings on your laptop to make sure the laptop is set to extend the display to the external monitor.
- Restart your laptop and monitor to see if that resolves the issue.
If these steps don't help, it's possible that there could be an issue with the monitor or the laptop itself. In that case, you may need to contact the manufacturer for further assistance.
DeLl PrInTeR SuPpOrT PhOnE NuMbEr {+1* 877 *~ SCAMMER69 } NuMbEr
-FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 2500 spams per day, and it's not keeping up with the flood. Please help us out.
Dell lcd keys locked
no TV stated at all. they have a model number on each made.
try new batteries in remote
at dell.com read the manual see all words locked in your manual
some do have locks. most times holding a button for 10 full seconds does the unlock.
