20 Most Recent
Westinghouse LTV-19W3 19 in. LCD Television Questions & Answers
Westinghouse tv has only half of picture on screen
screen driver has failed on the screen, also known as the t-con board this controls the lcd screen, looks to me as its failed and just needs replacing depending on your location price is from £5 upwards in UK just make sure you replace the board with the same board as the original. t-con board is located on the back of the screen under the metal shield with the wires coming out going to the main av board 4 screws and 2- 4 clips on the board connecting the ribbons to the screen itself.
19 in blue screen only sound works great
un plug the tv for 3 minutes to reset it, then plug it back in. if this dont fix it, please get back with me and tell me if you had any power outtages or surges. some times lightning strikes can burn out the tuner when it strikes the cable line.
I have no picture but I have sound from program
Back-light fault. Check and replace damaged component/s at its back-light section circuit. Replace the back light inverter board as card basis, if necessary. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Can't turn on TV
hi there,if the fuses are the main problem try first checking the chord by turning it on and off without plugging it. to test if there is a conduction and or a current. bring a tester with you. if you know how to test a voltage might be well so easy. just first look in the specifications located behind your Television check if its using ohms or voltage just follow the diagram. to prevent electric shock.secondly try to locate the power supply or the transformer on the TV board then test it with out plugging. and locate for the fuses and test it first before you replace any of it. (make sure if you replace any of the components from your Tv board fits the same spec.if still the problem persist: it might as well be a board problem. check if there are evidence of burned ic's or resistors. if you are not capable of doing this all my suggestion will be Go to the expert to fix it for you...regards,xjc
Westinghouse model LTV-17v1sl When I move from
There are a few things that could be wrong. Before I start I have to let you know that if you are getting audio on while you are on TV mode than you switch to the av mode than most likely it is a settings issue. Number one thing you have to check is that all the cables are connected properly. You have to make sure that you are using the correct white and red connection on the back of the unit because you can accidently connect them in to the YPbPr connectors. Another thing to try is to check on the settings while you are on the av mode. Please make sure you have the internal audio on and not the external. If this does not work you can send me a quick email to
[email protected] and I will help you find a solution to your problem. Please rate my comment on this page.
Lighting
Are you saying that the light does not turn on at all and there is dark picture or what? please explain more
if the light is not coming on the inverter or the bulb is damamged. many time when the bulbs go this is due to improper cleaning. if someone cleaned the unit by spraying the cleaner on to the unit and not the rag, this may have damaged the bulb
I can not get my TV to turn on. I have changed the
If it is plugged into an outlet strip or surge suppressor be sure the strip is switched on and try to reset it. If you are plugged into a wall outlet check your circuit breaker to be sure its not tripped.
