20 Most Recent
Sharp LC-37D6U 37 in. LCD Television Questions & Answers
Our sharp LC-37D6U does not
The main tv Tuner signal board it is dead or it have problems,but tv still usable.Tries push the remote power switch off/on again everytimes OPC/Power LEDS lights flashes.Have to do this maybe 3 or 4 times for the tv to have a lite up LCD screen panel backlight to make the tv Tuner signal board to work again,for the tv to work.If still have same problems after 3 or 4 times power switch pushes off/on still have OPC/Power LEDS lights flashes.Mean the main tv Tuner signal board it is dead and can not be trying to save it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.This solution 100% will work,if ur tv main Tuner signal board still have life left in it.I do this every few days out of a week for my 46" Sharp Aquo LCD tv set,tv it work all the times.
Can fix the audio problem myself or is there a
Actually there is a service bulletin on this television. Sharp will repair the no sound problem for no charge. Call 800-237-4277. Please remember to provide feedback here if this helps you.
For some reason I can not get power to my tv
Start fromt the plug and move on to the fuse, the coils, the rectifier, and the SMPS. If there is mains on this stage and there is no output of +B then you need to replace the SM drive/Transformer/ allied components. If +B is present and the set does not trigg, there could be the main board failure.. it might prove difficult if your are not familiar with this PCB... Just check this out
Sharp LC-37d6u audio problem
Have you tried the reset buttons on the back of the TV?
It should be right below your Cable IN port.
If that doesn't work, you may have to take it into a repair shop for the main unit board to be replaced. The part # is KD352
It's $99.59 at Shopjimmy.com
So, don't let the repairman
rip you off.
Unpredictable audio output for no apparent reason
That click sound when the tv turns off is normal, that is
just the relay from the power supply shutting off.
When you turn the tv on, do you hear a faint “pop” noise
from the speaker? If so, the problem is with the heat sink under the audio IC.
Over time, the heat sink will lose its consistency and start to melt, thus
shorting out the audio circuit. To fix,
you’d need to clean off the melted residue on both sides of the audio IC as
well as replacing the heat sink with a newly redesigned Sharp Heat Insulation
Pad. It’s a pretty complicated fix, I suggest calling your local authorized
sharp service center to fix this problem.
The part is inexpensive, so you’re most likely looking at a labor charge
(maybe around $200ish) for the repair if they are not marking up the price too
much.
Sharp LC 37 D6U
much.
