20 Most Recent Philips Magnavox 15MF400T 15 in. LCD Television Questions & Answers
Remote code for Dish Network Remote for the Magnavox 15MF400T?
code for dish is 579
3/13/2018 3:05:34 PM • Philips Magnavox... • Answered on Mar 13, 2018
0answers
2answers
No sound or color after hooking up DTV converter box to this TV
Check the video signal if it is PALSICAM or NTSC
5/8/2017 8:40:23 PM • Philips Magnavox... • Answered on May 08, 2017
How do I fix my magnavox 15" LCD tv
What is the problem you faces with this TV? Provide more details, please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/3/2014 3:35:45 PM • Philips Magnavox... • Answered on Aug 03, 2014
I thought I asked this already but it does not
the backlight is either going out or the capacitor for the backlight is bad to where its not storing enough power to run the backlight the start capacitor must be good but the run capacitor might be bad usually the backlight itself goes bad but not if it turns on for a few seconds it would have to be the capacitor.
10/4/2013 6:27:00 PM • Philips Magnavox... • Answered on Oct 04, 2013
TV displays a "no signal message"
is there any picture at all ? if no signal message regardless of any signal input , ur ad board need to be change.
6/29/2013 5:12:19 AM • Philips Magnavox... • Answered on Jun 29, 2013
2answers
Magnavox 15mf605t/17 15'' LCD HDTV won't turn on
Have similar TV. If it is set to the PC source, it goes into standby when there is no signal, like a regular monitor. Even though the monitor is in standby, you can still press the Source button to change to, say, HD input, and will use the familiar on/off action when pressing Power on the remote.
A little weird, but I've gotten very used to it.
6/18/2013 1:49:14 AM • Philips Magnavox... • Answered on Jun 18, 2013
2answers
Solo enciende, inactiva demas funciones
hola tienes que chequear la fuente de alimentacion o power supply
si abres el tv vas a ver algun capacitor que esta alterado osea como prenado cualquier pregunta me puedes enviar un mensaje a mi correo electronico\;
buena suerte
[email protected]
3/29/2013 9:18:42 PM • Philips Magnavox... • Answered on Mar 29, 2013
2answers
Magnavox LCD HDTV starts on its own
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
2/4/2013 6:46:17 PM • Philips Magnavox... • Answered on Feb 04, 2013
Magnavox 15MF605T/17B how to remove the front panel to replace speakers?
I presume the back cover does not really open from the back or if it does you cannot see the speakers from the rear?which if you cannot see them with rear cover removed leaves two possible paths, the entire panel unit with the screen has to be removed and they are under it OR the entire front may be snapped together and has to be pryed out (if you see a seam or crack like area running around the side up front get a thin metal putty knife and try to open it, seen a lot of computer LCD monitors where they come apart from the front--and are snapped together much like some of our plastic remotes--have to go in from the front and not the rear.Do some careful looking to see what you have.
12/6/2012 4:11:12 AM • Philips Magnavox... • Answered on Dec 06, 2012
6answers
Problem with Magnavox 15MF605T/17B
Hi SgtHoagie and anyone else:
I ran across this problem too, at 1:30 this morning. At that time I had to get out of bed and try to figure out what the hell happened. It seems that my flat panel TV somehow got switched over to the computer monitor mode. When this happens, the light will turn an amber color. On the bottom of your flat panel you'll see some very small buttons, marked "MENU," "CH" "VOL" and "SOURCE." You'll want to click on the "Source" button and that will switch your flat panel back to the TV mode. Your flat panel TV can also be also used as computer monitor.
11/8/2011 3:22:26 PM • Philips Magnavox... • Answered on Nov 08, 2011
Philips Magnavox 15MF400T 15 in. LCD Television Logo
134 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
thought asked already but not
  • Televison & Video
