20 Most Recent Sony FWD-50PX2 50 in. Plasma Television Questions & Answers
Vertical Bars instead of Picture on Plasma TV - which board is the problem?
Hate to give you bad news but this sounds like panel issues. You could try a tcon but I seriously doubt it will help
1/8/2022 12:01:31 AM • Sony FWD-50PX2... • Answered on Jan 08, 2022
Black and white picture no color
Check the color mode set to Auto Mode
11/24/2013 3:06:19 PM • Sony FWD-50PX2... • Answered on Nov 24, 2013
Flicker screen
If any buffer board is faulty, this kind of fault can occur. Might have a panel fault too. It will be best to contact any service technician, to make it confirm. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/16/2013 6:16:47 PM • Sony FWD-50PX2... • Answered on Oct 16, 2013
0answers
Picture flickers and clicking sound coming from back of t.v.
The Z-Sustain should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Faults to almost all brand Plasmas will be the same as they are all built on similar chassis. Refer any one. You can get details.
11/15/2012 7:48:55 PM • Sony FWD-50PX2... • Answered on Nov 15, 2012
Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
6/4/2012 9:30:06 PM • Sony FWD-50PX2... • Answered on Jun 04, 2012
When we are watching programs
Hi you have a bad sustain Board. Either the lest or the right sustain board is bad. You can get parts for this TV at www.interliquidparts.com
6/13/2011 9:20:46 PM • Sony FWD-50PX2... • Answered on Jun 13, 2011
When the TV turned on
first, make sure the TV is correctly plugged into the wall. You can try another outlet. If that doesn't work, then your TV is certainly having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on......
All these can be checked on the power supply board.......
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
Yours sincerely.
Elect_Comp.
5/16/2011 11:27:14 PM • Sony FWD-50PX2... • Answered on May 16, 2011
Where can I repair power
Any tv repair shops,look for them on the telephone Yellow pages.U mean litterly the power supply board taken out of the tv unit,yes,if they except the job.All tv shops,like their customers keep their parts in the tvs,Some charged u to come out and have estamate for the cost for repair some don't charge just look at the problems to telling u.
2/8/2011 9:13:09 PM • Sony FWD-50PX2... • Answered on Feb 08, 2011
My Sony Flat Panel Display
Unplug,replug tv back in an hour later.Tv now reset it self back to factory setting.Now it should work.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
9/13/2010 6:43:24 AM • Sony FWD-50PX2... • Answered on Sep 13, 2010
Have hd cable connecting receiver to tv. HD
U check the channels display?Anythings less than 1080i is standard def channels.
3/17/2010 1:26:58 AM • Sony FWD-50PX2... • Answered on Mar 17, 2010
The screen just went off. i can still here the
Power supply. Contact Vizio support, and they can point you in the right direction.
the VizParts people are the official parts suppliers, and they also have better pricing than anyone else on the web from what I've seen.
Swapping the power supply is pretty easy.
12/19/2009 5:48:42 PM • Sony FWD-50PX2... • Answered on Dec 19, 2009
2answers
Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
4/24/2008 3:59:36 AM • Sony FWD-50PX2... • Answered on Apr 24, 2008
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 2 days ago
Sony FWD-50PX2 50 in. Plasma Television Logo
24 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
loud bang unit stopped working
  • Televison & Video
