20 Most Recent Nuvo ViceVersa TIX Toaster TC 61 By Designer: Luca Trazzi Questions & Answers
The heating element is not functioning..
You need to see if the heating element is getting voltage. You can do this with a multimeter set to volts. Use a scale that is greater than 200 volts. If the element is getting 120v and is not getting hot then it is most likely the heating element.
Bob Janelli I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
10/1/2009 11:52:17 PM • Nuvo ViceVersa... • Answered on Oct 01, 2009
0answers
Question about the De Longhi Magnifica coffee machine.
These machines need dealer servicing every 6 to 12 months. They don't tell you that when you buy them. There are some ideas here https://www.google.com/search?q=De+Longhi+Magnifica+warning+triangle ..
4/16/2024 2:41:15 AM • Coffee Makers &... • Answered 2 hours ago
SCHAERER VERISMO 701 AMBIANTE 15 ESPRESSO MACHINE. We have to reset the Verismo 701 continuously even when we have the beans container filled up to the top.
Question edited for clarity. These machine need dealer servicing every 6 to 9 months depending on usage. They don't tell you this when you buy them, but I have been fighting these types of machines for the 9 years before I retired. One place had 2 machines and another has 6. Once machine did 1,200 cups a days and was serviced every month. Airport Business Class Lounges. ..
4/12/2024 5:42:30 AM • Coffee Makers &... • Answered 3 days ago
2answers
Where can I find Cecilware 3K-GB-LD Cappuccino machine Error Codes, I'm getting ERR 1 on my machine
To find Cecilware 3K-GB-LD Cappuccino machine error codes like "ERR 1," refer to the machine's user manual or technical documentation. Alternatively, contact Cecilware customer support for assistance in diagnosing and resolving the specific error code on your machine.
4/6/2024 8:13:43 PM • Coffee Makers &... • Answered on Apr 06, 2024
Capresso "Perk" Percolator Coffee Maker, 12 Cup. I have 2 percolator model 405.05 and the cord burned out on both i would like to replace the cords
Question edited for a lot more clarity. This is a very standard appliance plug that you can get from Walmart, Home Depot any small appliance store or even Amazon https://ecscoffee.com/products/capresso-12-cup-perculator-405-05 They look to be here https://www.google.com/search?q=percolator+model+405.05+replacement+cord ..
4/3/2024 6:29:51 PM • Coffee Makers &... • Answered on Apr 03, 2024
Looking for instructions for sansui espresso maker. model EM 208. 850 W.
Sasui em 208 coffee machine manual
3/22/2024 3:57:55 PM • Coffee Makers &... • Answered on Mar 22, 2024
2answers
Russell Hobbs Kudos 11418 coffee machine. Does anyone have a manual for it please?
I would go on the Russel Hobbs web site and download one. https://en.russellhobbs.com/user-manuals
3/21/2024 8:56:43 PM • Coffee Makers &... • Answered on Mar 21, 2024
How to repair toggle switches on cuisinart dgb900 coffee maker
You can replace them but unlikely to repair them. The casing will come apart, with some difficulty. Remove the old switch, source an identical new switch and fit it.
3/12/2024 11:29:39 PM • Coffee Makers &... • Answered on Mar 12, 2024
Why Jura ENA 1 wont turn on?
You simply have power supply board problem(PSU)
2/29/2024 6:17:17 AM • Coffee Makers &... • Answered on Feb 29, 2024
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
2/16/2024 6:02:28 PM • Coffee Makers &... • Answered on Feb 16, 2024
What does a CIMBALI M34 CODES ERROR 053 mean?
That .depends on software and configuration. It is not a universal code You might find help in the manual. CIMBALI M34 SELECTRON USE AND INSTALLATION Pdf Download ' ManualsLib Inspect Electrical Supply: Ensure that the machine is receiving proper electrical power. Sometimes, an interruption in the power supply can trigger error codes. Clean Components: Check if any components related to coffee grounds or filters are dirty or clogged. Clean the underpan gasket, filter holes, and filter holder outlet hole. Coffee Ground Quality: Verify that the coffee grounds are of the correct consistency. If they are too coarse or too old, it can affect the machine's operation. Discharge System: Examine the discharge system for any blockages.
2/15/2024 9:55:06 PM • Coffee Makers &... • Answered on Feb 15, 2024
Nuvo ViceVersa TIX Toaster TC 61 By Designer: Luca Trazzi Logo
10 questions posted
Top Nuvo Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Nuvo Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Nuvo Coffee Makers & Espresso...
  • Nuvo Coffee Makers & Espresso...
Most Popular Question
heating element not functioning
  • Coffee Makers & Espresso Machines
