20 Most Recent
Shure PGX-2 Wireless Handheld Microphone Transmitter PGX2SM58H6 Microphone Questions & Answers
HOW TO REMOVE CIRCUIT BOARD FROM SHURE PGX2/SM58
First, unscrew the cartridge from the top. The round circuit board on top of the transmitter has a cutout on the switch side. Slide a screwdriver through that cutout and pop out the bezel the surrounds the switch. Remove the spring clip that is around the round circuit board and slide out the circuit board.
Shure PGX2/SM58 Power Button
Unscrew the cartridge from the top. Slide a screw driver down inside to pop off the switch cover. Remove the large "c" clip to remove the circuit board.
Pgx2 manual
Call Shure at 800-516-2525. They are experts on their products and can help you troubleshoot. This type of problem is nearly impossible to troubleshoot in a forum.
PGX4 receiver/PGX2 bodypack/WL93 lavalier>> mic
Unfortunately, it is nearly impossible to troubleshoot this over email. I suggest calling Shure at 800-516-2525. They can help you trouble shoot the problem. Make certain you have the wireless system with you when you call them.
The microphone is no power
This mic does require a longer power button "press" cycle...used during on and off in hopes you don't turn mic off or on accidentally. Check the battery, battery polarity and battery connection...no luck, then it's probably been dropped one time too many.
I got a new mic
The mic is probably in a different frequency band than the receiver. Look at the stickers on the receiver and the mic to make certain they operate in the same frequency range.
