20 Most Recent
Philips DVP-3005 DVD Player Questions & Answers
3005 works, and after a minute then stand works then stands, and so on
I have a DVP3005 too, and this works for a while. Then suddenly jumps back 1 chapter. Then plays for ? little while, and jumps back one chapter again.
I thought it might be a temperature problem(the prcessor was very hot), so I took the lid off and cooled it down, but the error came back.
I have dismantled the front PCB, and it is not a problem with the switches, and it is not the remotecontrol that causes this error. Is it worth troubleshooting?
[email protected] Norway
NO VIDEO BUT HAVE SOUND
Good day! Try to check the rca jack video input.Replace it with new one if defective. Also check the progressive scan features if activated. If it is activated check your TV if supported by progressive scan features, because some TV is not supported by progressive scan.You can deactivate it by turning off or activate the interlace mode.Press the open/close to open disk tray. And press the numeric keypad 1 for few seconds. Hope its help.
Can i unlock my philips dvp3005 dvd player
Heres how
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
Enjoy
I have a Philips 3800/93
1. Press the Setup button on your remote control
2. Using your remote control, highlight but do not select the Preferences menu
3. Press the 1 , 3 , 8 , 9 , 3 , 1 buttons on your remote control
4. Using the Up and Down buttons on your remote control select 0 for multi-region playback
5. Press the Enter button on your remote control
6. Press the Enter button on your remote control
For that you will need a real universal remote, one like this one
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
As I am watching a
It sounds as if you have inadvertantly locked your dvd player. Try using the code 136900. If this passcode is accepted, then access the general setup menu (using your remote) and choose the Disc Unlock option.
I hope this helps. I completely relate to the frustration of this very problem.
Hello Sir,
I would take it back and exchange it ,,if you purchased it new,,But if you bought it used,,and cant take it back,,I would take the top off ,,You can acces the dvd to retrieve disk and maybe see what the prob is,,thanks and goodluck
