20 Most Recent Belkin (F5D7000) 802.11g/b Wireless Adapter Questions & Answers
Acquiring network address xp
You must have at least the date right and the time otherwise you get this response. Set the time and date on your computer to solve this issue. Let me know if this works.
12/6/2013 12:57:54 AM • Belkin (F5D7000)... • Answered on Dec 06, 2013
Necesito el software de mi
perdi el cd de mi belkin router f7d2301 v1
11/25/2012 5:22:02 AM • Belkin (F5D7000)... • Answered on Nov 25, 2012
I have a belkin 7000
the USB may have shorted out if it is not being recognized.
2. check the usb port to see if you are getting proper contact.
3. if you have a flex cable to the USB adapter it may well be a broken data wire in the cable at the strain relief.
4. contact Belkin if the unit is under warranty they will give you a replacement.
9/21/2011 8:09:25 PM • Belkin (F5D7000)... • Answered on Sep 21, 2011
2answers
Connecting to the internet
  1. Start Menu
  2. Run
  3. cmd
  4. Ipconfig and check if your IP starts with 192.168... if so check the gatway if not you have to configure the router so it can give you an IP address
5/23/2011 9:36:30 PM • Belkin (F5D7000)... • Answered on May 23, 2011
What site do i go
You can download the driver for this wireless adapter from this link.<br /><br /><a href="http://en-us-support.belkin.com/app/answers/detail/a_id/303">http://en-us-support.belkin.com/app/answers/detail/a_id/303</a><br /><br />
8/24/2010 5:16:44 PM • Belkin (F5D7000)... • Answered on Aug 24, 2010
Need set up for router
look for IP address in Belkin riouter insructions OR
irt may be printed on the bottom of the wireless router
access this IP address using run command || 111.90.20.01 EXAMPLE
Or enter in I E browser address space: back slash back slash \ then IP address see dots between entries
Once in there you will find registration area fill in and save at bottom of devie webpage
should be exact correct on all entries
some info may be preset or filled in partially
6/11/2010 8:02:53 PM • Belkin (F5D7000)... • Answered on Jun 11, 2010
2answers
How to set up wireless security for belkin 802.11g
Depends on what you can set up or what knowledge you have. I would use this for today's networks.
MAC Filtering: http://compnetworking.about.com/cs/wirelessproducts/qt/macaddress.htm
4/13/2010 9:50:57 AM • Belkin (F5D7000)... • Answered on Apr 13, 2010
Dell Inspiron 8200 has Dynex USB 2.0 Network
All you should need is the driver for the wireless adapter , you can download the driver from this website http://www.dynexsupport.com/product/?pid=DX-BUSB run the program to install the driver
To check the adapter is installed go into the device manager and see if its shown. Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc and see if you have a wireless adapter showing at all. are there any ? X or ! look under network adapters - click on the + and see if you have the adapter listed - check if it has any X or ! or ?
A useful tool to use, if you can copy onto the PC, http://www.xirrus.com/library/wifitools.php this will detect all the networks broadcasting - so you can now see if the adapter is working and if it will detect your wireless network
3/25/2010 12:40:33 PM • Belkin (F5D7000)... • Answered on Mar 25, 2010
2answers
Not recognizing driver
These belkin wireless cards are version dependant, on your card it shows you what version it is, use the driver for your version.
It tells you this on the support page on belkin.com
3/22/2010 4:53:06 PM • Belkin (F5D7000)... • Answered on Mar 22, 2010
Etaf, still no drivers detected for
Hello
You may need to do it manually,or when windows detects new hardware select the folder with the drivers then look in the subfolders of that file until you find the driver file.
Another way is to device manager and do a driver update on your adapter,pointing it towards the file on your zip drive.
YOu may need to extract all files from your zip drive to your hard drive or create a folder with the drivers in it.
3/22/2010 12:53:28 AM • Belkin (F5D7000)... • Answered on Mar 22, 2010
How to install belkin wireless mouse in a laptop?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
3/6/2010 7:13:11 PM • Belkin (F5D7000)... • Answered on Mar 06, 2010
Connection wireless adapter to laptop dell
Open up PC, Plug it wireless network into a PCI slot, turn on PC, the network device will be recognized and ask for drivers, you insert the CD/DVD that came with it, or use the software you downloaded from Belkin web site and install the WiFi card.. Run the Belkin software and it is installed. reboot PC, put case side back on.
3/2/2010 11:38:11 AM • Belkin (F5D7000)... • Answered on Mar 02, 2010
I just installed the card in my compaq server
Check with antenna whether it can receive the signal or not.
If antenna geting problem then you does not receive the signal
1/4/2010 10:03:59 AM • Belkin (F5D7000)... • Answered on Jan 04, 2010
I need to download driver for my 802.11 adapter
You could Download the same from :-
http://www.soft32.com/download_180190.html
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
12/10/2009 12:44:58 PM • Belkin (F5D7000)... • Answered on Dec 10, 2009
Hi- Ive got the belkin f5d 7000 and Ive lost my
You can go to the below website and download the driver:
http://www.belkin.com/support/article/?lid=en&pid=F5D7000&aid=6001&scid=0
You can either burn the software driver to a cd, or copy it to a flash drive.
On the computer with the wireless card, you will want to install the driver and it should work properly
7/16/2009 1:47:57 AM • Belkin (F5D7000)... • Answered on Jul 16, 2009
Belkin Wireless G won't connect
Make sure your router has no mac filtering. If there is mac filtering disable it and try again. If issue persist reset the router and set accordingly. If you need further help please post.
Good Luck
7/7/2009 10:28:19 PM • Belkin (F5D7000)... • Answered on Jul 07, 2009
Need network key
there is no set network key for that model... the network key is something set up on the router or wireless access point. You will need to talk with the administrator of that network to recieve the network key.
6/22/2009 3:24:17 PM • Belkin (F5D7000)... • Answered on Jun 22, 2009
Belkin (F5D7000) 802.11g/b Wireless Adapter Logo
43 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
ive got belkin f5d 7000 ive lost
  • Computers & Internet
