20 Most Recent Bosch 36 Inch Pyramid Chimney Hood - Black Questions & Answers
2answers
Screen over chimney?
Screen is not the correct product to use to bird or squirrel proof the chimney. Your local hardware will have what is known as hardware cloth. It's actually a heavy wire mesh with 1/4" or 1/2" square pattern. you should be able to purchase it, by the foot, off a roll.
10/30/2014 8:48:58 PM • Bosch 36 Inch... • Answered on Oct 30, 2014
Bosch built in dishwasher -spray
The fault is the pump pressure is low and must be checked . make sure that in the first place there is no dirt that is clogging the filter in the pump that is causing the drop of pressure in the pump.
So remove the pump and do a good cleaning , use a reverse flushing to take out all dirt.Now make sure that the inlet to the pump is also clean.
Now reset and test the pressure. If the pressure is good then your top spray arm will will rotate and spray.
If not the pump is a suspect and must be checked for perfomance or a replacement is the other option.
Finally make sure that the voltage to the pump is in order.
12/17/2010 12:07:45 PM • Bosch 36 Inch... • Answered on Dec 17, 2010
2answers
Bosch dishwasher won't latch
No you did good in ordering a latch ,that is a common issue i find with the bosch d/w, for no apparent reason the latch locks itself with the door open. Look at the door where the male part of the latch goes into the door, you will see that is locked. if you take it apart and manually unlock the latch u stand to break it. Again you did good on ordering the latch.
7/18/2010 10:09:34 PM • Bosch 36 Inch... • Answered on Jul 18, 2010
Our DLX series dishwasher leaves
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
1/20/2010 12:38:19 AM • Bosch 36 Inch... • Answered on Jan 20, 2010
Bosch dishwasher (approx. 5 years old), won't
If a DW is not level on the floor then this can stop the latch from connecting and closing door.
12/28/2009 6:33:33 PM • Bosch 36 Inch... • Answered on Dec 28, 2009
Dishwasher wont fill
Make sure the dishwasher is not stuck in some kind of error mode. Make sure the water valve is turned on. Take the bottom front service door off and locate the water valve on the front left bottom of the machine. Make sure there are wires connected to it. If it's still not working, pick up a cheap electrical multimeter. Set it to the resistance setting, and remove the wires from the water valve. Test the resistance across the water valve's terminals. If the resistance is very high, or infinity, the water valve needs to be replaced. If the water valve is ok, turn the dishwasher on and test the voltage across the wires that go to the water valve at a time in the cycle when you know the dishwasher's controller will be trying to let water in. It may be either ac or dc voltage, so try both settings on the meter if you don't get a reading. If no voltage is read across those wires, open up the dishwasher and find the circuit board that the water valve's wires connect to, and make sure they're connected to the board properly. If that still doesn't work, there's a problem with the dishwasher's control board. Look for a square or rectangular blue, gray, black, white box on the circuit board near where the wire plugs in. This is the mechanical switch that turns on the power to the water valve when the computer sends a signal that it wants water. This switch may be jammed up. Try tapping it firmly with screwdriver. If that doesn't work, you can desolder the power switch and solder on a new one. If that doesn't work, you'll need to replace the board or do some advanced work on it.
9/17/2009 10:30:32 AM • Bosch 36 Inch... • Answered on Sep 17, 2009
Bosch dishwasher model SMU4052UC/14, Won't fill
you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
5/6/2009 2:05:29 PM • Bosch 36 Inch... • Answered on May 06, 2009
Bosch dishwasher shu 3302
JiXing Hardware & Mesh Products co.,ltd ,established in 2005, owns two factories in China mainland.
We can supply many kinds of aluminum cooker hood filters,grease filters,,hardware parts,wire shelf,wire and wire mesh.
Our products are sold all over the world , we can assure the good quality with competitive price.
Hope to establish a long-term business relationship with you.
contact info: [email protected]
TEL:0086-318-7803299
FAX:0086-318-7755255
12/4/2007 1:41:34 AM • Bosch 36 Inch... • Answered on Dec 04, 2007
Bosch HGI8054UC warming drawer won't close completely
The slides require replacing.The functions part on the rear of either the right or left side has failed causing your drawer not to close. It cannot lock so the spring pushes it out. The part on the rear that locks it in, and ejects it out some how gets damaged. Need a T 20 star/torque bit to replace. The part number for the slides is 12024638. You can pull out the drawer but be careful of the rail that will stick out. Don't let the drawer land on your feet. If you don't order the parts yourself and install this, you may call the Bosch service to do such for you --though you have noted the expense.
10/22/2023 1:37:41 AM • Bosch Kitchen... • Answered on Oct 22, 2023
What are the dimensions of a Bosch WFF 2001 washing machine please
Most domestic washing machines are built to a standard size regardless of manufacturer. So if a standard machine was removed this machine should fit. The standard height is 85cm and the width is 60cm. The depth can vary depending on the drum size. A bigger capacity machine will stick out further from under the counter top.
7/30/2023 8:59:36 AM • Bosch Kitchen... • Answered on Jul 30, 2023
Bosch gas range no lower ignitor for bake no upper ignitor for broil display is fine no type of error code no other issue any recommendations?
It sounds like there is an issue with the ignition system of your Bosch gas range. The fact that the display is fine, and no error codes are being displayed, suggests that the problem is with the ignition system itself.
  • The first thing to check is the ignition switch, it could be faulty and not sending power to the ignition system.
  • Check the wiring, it could be loose or corroded preventing power to reach the ignition system.
  • The next thing to check would be the spark module, which controls the spark that lights the gas. If the spark module is malfunctioning, it will not send a spark to the ignition system.
  • Lastly, the oven and broiler igniters may be faulty and need to be replaced.
It's important to note that working with gas appliances can be dangerous, if you're not comfortable troubleshooting, it's best to contact a professional for repairs or contact Bosch customer service for further assistance. Request for a senior technician or supervisor to take a look at it and provide a resolution. Regenerate response
1/18/2023 3:26:26 AM • Bosch Kitchen... • Answered on Jan 18, 2023
My Bosch HSB745 stove is just totally off, no display but power is available and connected
Although there is power entering the range (as measured at the electrical connection for the inlet), the range will not turn on by itself. Despite the fact that there is no shortage of gas, the gas top will not light up.
5/12/2022 8:56:36 AM • Bosch Kitchen... • Answered on May 12, 2022
2answers
I have a bosch exact
Well i now have the answer to the bosch stove dilemmas if you have a glass touch panel on your bosch stove and you can't get the touch buttons to work right then check the circut board on the back of the glass it is cheaply held to the glass with a non hardening caulk and when your oven heats up the glass panel
the caulk gets so soft that the circut board and the caulk seperate causing inconsistent button operation. To solve this push the circut board and its frame back to the glass then get some aluminium tape at the building supply you shop at in the heating section and tape it into place so it can't seperate anymore then it should work for you. Make sure you have everything grounded properly.If you are concerned about the grounding you can use duct tape to be safe. ( there has been a lot of complaints about glass touch panel incosistentcies on more than one model so im 90% sure this will fix those too).
5/11/2022 10:04:35 PM • Bosch Kitchen... • Answered on May 11, 2022
2answers
Bosch gas oven will not light on bake or broil.
CALL A SERVICE COMPANY WE DO NOT MAKE RECOMENDATIONS ON GAS APPLIANCES THEY WANNA GO BOOM IF YOU MESS UP
9/2/2021 12:32:07 PM • Bosch Kitchen... • Answered on Sep 02, 2021
Why doesn't the red 'on and off' light turn off?
1. Defective switch 2. Defective wiring
6/26/2021 3:13:28 PM • Bosch Kitchen... • Answered on Jun 26, 2021
2answers
My BOSCH free standing electric range intermittently does not achieve set temperature, why?
Erratic temperature control
11/2/2020 3:06:01 PM • Bosch Kitchen... • Answered on Nov 02, 2020
I have a Bosch HGI8056UC range that the stove in a bake mode it's not working. In broil mode working.
Near your Burner will likely be a metal heater that glows RED HOT next to the gas burner and when the heat is detected the gas is let go to light. A Safety and a way to light the gas. If you look it may glow slightly but needs to glow full bore to light. This is the most common failure. If you get a kit that has Wire Nuts be sure they are Ceramic Wire Nuts due to the heat or the plastic ones will melt off exposing the wires. Good Luck.
11/18/2019 2:00:07 AM • Bosch Kitchen... • Answered on Nov 18, 2019
Control panel doesn't display any light
Use digital tester 1st test the power outlet if theres a voltageif OK check the power cord if broken if OK check the fuse using continuity test/setting,
7/15/2019 9:52:32 AM • Bosch Kitchen... • Answered on Jul 15, 2019
Kitchen Ranges Logo
11 questions posted
Top Bosch Kitchen Ranges Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Kitchen Ranges
Most Popular Question
bosch built in dishwasher spray
  • Kitchen Ranges
