20 Most Recent
Garmin eTrex Vista Cx GPS Receiver Questions & Answers
Vista etrex cx will not acquire satellites
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
It soes not a acquire
I have this unit and have not had a problem acquiring satellites except under dense canapy cover. In open view you should always be able to acquire enough satellites. You should be able to see the available satellites on the start up screen and watch them being acquired. According to the manual if a satellite fix is not established a list of solutions is suppose to appear. Hope this helps.
Garmin etrex ledgend c:
When track
Hello
Check both your track and map settings. Make sure that "show track on map" is not selected in your map settings, and in your track settings try erasing all previous tracks.
Hope this helps!
My etrex vista cx will
as its new, it would be unwise to fiddle around with it. Return it for exchange,
Before you do though make sure that the batteries are good and have been inserted in the correct polarity.
Etrex Vista is a very robust unit and most reliable generally, so this is unusual.
Please rate my help++++Thanks fo using FIXYA
Runs fine on external power. Does not work on
Hello :
It seems that the batteries are dead . You need to replace them . When battery is dead it can't be recharged anymore .
If that didn't fix the problem , then I recommend you to clean the batteries base where the batteries set with a q-tip and alcohol containing liquid .
PLEASE RATE !
REGARDS .
My eTREX VISTA won't get a satelite fix any more
The unit needs to have the screen facing up. The unit will not read if it is vertical. Garmin cust serv finally helped me with that one. Once you turn on the unit, it could take up to 20 minutes (usually about 3) to grab satelites.
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Etrex will not turn on
Sorry to say but this is already a dead unit and I think if this unit is still under warranty Garmion will have it repair but if its already out of warranty they will just advice you to have the unit replace by a new one...
Freeze up
I have been having the same issue. I have both the Topo and City Nav software. I seems more consistent when using the City Nav data. Changed microSD cards brand and still the same issue. I was told to also update to 2.60, but it did not help
Screen Blanks
11-08-07
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
