20 Most Recent Furuno GP7000F/NT GPS Receiver Questions & Answers
0answers
Water temp settings
HelloGo to page [2-6] of its user manual. All adjustments to be done to get the water teperature has been described here with details. It is difficult ot get all these details by this window, as it contains tables and charts, whci cannot be uploaded by this window. OK.
1/4/2012 9:52:29 AM • Furuno... • Answered on Jan 04, 2012
0answers
How do I reset my
Be the first to answer 8/19/2011 9:34:13 AM • Furuno... • Posted on Aug 19, 2011Be the first to answer
2answers
GP700F Airmar P66 to TM260
you must run 50KHz for deep water, so you will have to solve the interference problem to benefit from the power
4/27/2010 8:40:45 PM • Furuno... • Answered on Apr 27, 2010
Furuno sounder trandecer problems
the leading edge of the ducer should be higher than the aft portion. The leading edge must not be below the bottom of the transom. To determine if it is turbulence or radiated interference, put the boat in neutral and run motor up in RPM, if it fails then, with boat stationary, then proximity to motor is a problem and you should buy and in-hull ducer. glueing the transom ducer may or may not work well.
1/16/2010 5:26:21 PM • Furuno... • Answered on Jan 16, 2010
Installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
1/15/2010 4:38:23 AM • Furuno... • Answered on Jan 15, 2010
How to reset unit
thanks my problem is fix
11/16/2008 11:29:09 PM • Furuno... • Answered on Nov 16, 2008
Furuno GP31 Navigator. How do I can change language from German to English please?
Question edited for clarity.Page 75 of the manual refershttps://www.manualslib.com/manual/1183586/Furuno-Gp-39.html?page=75Menu - System - LanguageMenu (the U with two dots over it Umlaut) - System - Sprache..
4/1/2023 3:09:40 AM • Furuno GPS • Answered on Apr 01, 2023
What is the unit of measurement of the Furuno GP 1650 video sounder?
There are set by you to feet, metres, 'F or 'C, knots, kph, or mph.From a bit more reading, depth is Feet, distance is Nautical Miles. Temperature you have a choice.Note: The water temperature graph can beset on or off (See page 11-4.). The temperature scale is fixed between 20-80 °F (0 to30°C).Read the manualhttps://www.furunousa.com/-/media/sites/furuno/document_library/documents/manuals/public_manuals/gp1650fdf_operators_manual_version_m.pdf..
2/20/2021 9:03:42 PM • Furuno GPS • Answered on Feb 20, 2021
Furuno 1650F GPS. How do I replace the internal battery?
You would obviously be better served if you learned how to google it https://downeastboatforum.com/threads/1650-battery-replacement.12881/
9/29/2020 6:39:52 PM • Furuno GPS • Answered on Sep 29, 2020
How to connect furuno gp39 NMEA0183 to computer
https://www.youtube.com/watch?v=AQW4EoQPM00 hope this helps if so leave some feedback 8]
5/21/2020 5:53:32 PM • Furuno GPS • Answered on May 21, 2020
Our furuno fcv 587 will not turn on. Fuses appear to be ok
Possibly voltage too low, faulty unit, no power coming to the unit.
10/9/2018 12:49:30 PM • Furuno GPS • Answered on Oct 09, 2018
Furuno GP7000F/NT GPS Receiver Logo
Popular Tags
13 questions posted
Top Furuno GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Furuno GPS Expert? Answer questions, earn points and help others
View Most Popular
Furuno GPS
  • Furuno GPS
Most Popular Question
gp700f airmar p66 tm260
  • GPS
