20 Most Recent
Apple 12" iBook G3 700Mhz with 256 RAM, 20GB CD Drive (p/n IBG3-700-CD)-Linited Supply PC Notebook Questions & Answers
How do i boot apple ibook laptop from cd
Insert the disc (I know, duh), restart/start while holding down the "C" key.
I know this is an old question, and I hope you've already found your answer, but perhaps this will help someone.
My ibook g3 running slow
If you have the original Install CDs that came with the iBook put in
Install Disk 1.
When the Menu Bar appears go to Disk Utility (under file manu). Choose your HD and look for
the S.M.A.R.T. status. It should be Verified. Then choose Repair
Permissions. After that is done choose Repair Disk.
If none of this works find the Hardware Test Disk and run that.
The sims game download instructions
Use Disk Utility to create a "CD/DVD master" disk image file.
Depending on the copy protection resident on the actual disk, this may or may not succeed. Some commercial disks have deliberate bad sectors which prevent you from making disk images of them.
If successful, then double clicking the .cdr image file will mount the disk to the desktop as if there was a CD resident.
Papa
Replacing hard drive
Hello frank you can get info of how to change your apple g3ibook on various website like www.eserviceinfo.com and many other by searching on google and by typing the ibookseries followed by free manual or visite www.apple.com for more info
M7318 batery
Don't waste your time replacing (only) the bad cells in a laptop battery. The older ("good") ones will be weaker, and will expire next.. quickly, and likely damage the new ones.
All cells must be replaced NEW with equal/same milliamp ratings.
That is true, and useful in SOME laptops, but unfortunately, NOT yours!
Apple uses a small logic circuit in its batteries that "remembers" when it was made, how long it has been used, and when it "died". And even with new cells, this circuit will prevent the iBook from "recognizing" the battery.
Sorry to bear bad news. Dispose of the battery in a safe place (not an incinerator)
I dropped my mac lap top and the screen is a bit fuzzy, how can I fix it?
Thank for contacting Fixya, I will be glad to assist you. You cannot, without having a diagnostics performed by a certified Apple technician or Apple Authorized Service Provider. You may have damaged the video graphics card on the main logic board of your MacbookMacbook Pro.Unless you have knowledge on how to go in and physically troubleshoot this geniune hardware issue, I would recommend you do you to your local Apple retail store Genius bar, or Apple Authorized Service center near you and have your Macbook looked at.Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.
Apple Retail Store(Genius bar - need to set appointment via this website link, if planning on visiting Apple store of choice in your immediate area)
Apple Authorized Service ProviderYou don't want to keep turning on the Macbook until you have it checked because it could affect more than just the video graphics card.Regards,-The MacTechTrainer.
I have a Sanyo Xacti 10 MP that records with date and time but when I put the SD card in my Apple laptop and download the videos, the date and time seems to not stay on the videos.
The date and time information may not be embedded in the video file itself, but rather in the metadata of the file. When you transfer the video from your camera to your computer, the metadata may not be transferred along with the video.
To preserve the date and time information on your downloaded videos, you can try the following:
- Use a video player that displays metadata: Some media players, such as VLC media player, allow you to view the metadata of a video file. If the metadata contains the date and time information, you may be able to view it using such a player.
- Transfer the video using a program that preserves metadata: Some file transfer programs, such as Image Capture on Mac, will preserve metadata when transferring files. You may try using such a program to transfer your videos.
- Use a metadata editor to add date and time information: You can try using a metadata editor, such as ExifTool, to add the date and time information to your video files.
It's worth noting that not all video file formats support metadata, so depending on the format of your video files, it may not be possible to preserve the date and time information.
How to factory reset iMac without login or keyboard?
To factory reset an iMac without a login or keyboard, you can try the following steps:
- Boot the iMac in Target Disk Mode: Connect the iMac to another Mac using a Thunderbolt cable. Power on the iMac while holding down the T key. The iMac should appear as an external disk on the other Mac.
- Reinstall macOS: Open the Disk Utility app on the other Mac and select the iMac disk. Choose "Erase" and follow the on-screen instructions to erase the iMac's drive. After erasing, quit Disk Utility and follow the on-screen instructions to reinstall macOS.
- Restore from Time Machine Backup: If you have a Time Machine backup of the iMac, you can restore the backup to the iMac after reinstalling macOS.
If these steps don't work, you may need to seek assistance from an Apple Store or a professional repair service.
I have a new MacMini 2021 Monterrey O/S. I use Zoom but my Gear Head Webcam F#2 4.8mm is not on or is not connecting? IS it compatible with Apple Monterrey O/S?
It's possible that your Gear Head Webcam F#2 4.8mm is not compatible with the new MacMini 2021 running the Monterrey operating system (macOS Monterey).
The best way to check for compatibility is to visit Gear Head website and check for the compatibility list for the webcam with the MacMini 2021 running the Monterrey operating system. If the webcam is not on the list, it's possible that it may not be compatible with the new operating system.
If the webcam is not compatible with the new operating system, it may not be able to connect to the MacMini or be recognized by the Zoom app.
Alternatively, you can try connecting the webcam to the MacMini using a USB-C adapter and see if that resolves the issue.
You may also want to check if there is any new firmware update available for the webcam or the Zoom app that might resolve the issue.
If the issue still persists, it would be best to contact Gear Head customer support for further assistance and check if there is a way to make the webcam compatible with the new operating system or if there is any other solution that can be provided.
