20 Most Recent
Jensen VM9710DTS DVD/CD/MP3/WMA 7" Motorized Touch-Screen With TV Tuner Car Video Player Questions & Answers
Jensen vm9022 Disable touch screen???
try reentering the code. if not the screen whent out. i bought one of thees screens. and had to return it more than 4 times the screen whent out . cd player didnt work .ect.....ect...
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
