20 Most Recent
GE Monogram ZISx420DR 42-inch Side by Side Panel Ready Built-In Refrigerator with Dispenser Questions & Answers
Noise
Is the noise constant or sporadic?
Too cold
it must have gotten too cold in the refrigerator what are the settings at and did you change these , did you have a house sitter and did they change things
GE Monogram series side by
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The opening should be at the top probably behind the plastic removable cover.
My water dispenser and water to ice maker isn't
my monogram ice maker wont make ice. it is on, the water fills the pan but thats as far as it gets. the area is cold. the hoses appear open. i have cleaned the dust of the compresser. what else can i do before i call the repair man?
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
I have a monogram zis 42d side by side the freezer
I have this same problem. Now, the freezer will not get cold enough, but still water runs down into the ice bin and just turns into a big solid block of ice. The water is dripping from the top of the freezer compartment. I have disconnected the water coming to the refrig to not allow it to make ice, but still happening. Please post if you have found a solution? Defroster issues?
