20 Most Recent Sony VAIO VGN-FS742/W Notebook Questions & Answers
Drivers windows 7
go to sony website and download the driver or use driver pack solution
12/5/2013 8:29:56 AM • Sony VAIO... • Answered on Dec 05, 2013
0answers
Disassemble
Be the first to answer 8/26/2013 3:43:24 PM • Sony VAIO... • Posted on Aug 26, 2013Be the first to answer
Need hard drive for Sony Vaio VGN-FS742/W
If it's an IDE? Newegg has a 320GB. SATA can go much bigger, but Sony linked your model to a IDE hard drive.http://www.docs.sony.com/release/994630300_Rev_D_NO_PHONE.pdf
10/13/2012 6:11:11 PM • Sony VAIO... • Answered on Oct 13, 2012
Vgnfs742w runs slow
You have some viruses and malware.Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
7/18/2012 9:10:08 AM • Sony VAIO... • Answered on Jul 18, 2012
I have a laptop that
There is no commercially avaliable way to rollback from Win 7 to Vista, the only way is to install Vista over the top of Windows 7.
7/12/2011 5:12:53 AM • Sony VAIO... • Answered on Jul 12, 2011
Hi we are looking for a reliable cheap and quality
Hi we were also facing same problem like you are we were confused where to buy a quality battery then a friend referred me to buy from http://www.richbattery.com and i was very much satisfied they also have a large collection of batteries from all manufacturer's i will post a link to Sony batteries so you can check http://www.richbattery.com/Sony_c_42387.html thanks
7/10/2011 9:12:30 AM • Sony VAIO... • Answered on Jul 10, 2011
I want to disable sata
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
6/29/2011 11:03:01 AM • Sony VAIO... • Answered on Jun 29, 2011
Sata enable/disable is not appearing
1. Turn Off the computer
2. Try taking out the hard drive and put it back in
3. Go to the BIOS again... see if the BIOS detected the hard drive otherwise
4. Replace the hard drive
6/29/2011 9:28:01 AM • Sony VAIO... • Answered on Jun 29, 2011
It sounds like a slow
You can speed up a slow running computer by:
Running a disk cleanup
Running Disk Defragmenter
Cleaning system for viruses
Repairing Registry Errors.
Please see the link below to speed up your computer.
6/20/2011 6:04:40 AM • Sony VAIO... • Answered on Jun 20, 2011
Can sony vaio VGN-FS742/W run
Yes the Sony should run Win 7 although its designed for XP. For Win 7 to run properly you will need to max out the memory to 2GB.
I have installed Win 7 on plenty of older laptops without any problems. You won't be able to use the aero glass features (see through taskbar and window borders) as the graphics chipset doesn't support that feature but everything should work well once you have enough memory installed.
Regards.
4/21/2011 3:42:00 PM • Sony VAIO... • Answered on Apr 21, 2011
2answers
Does the PCG 8131L have
They are usually right along the front of the laptop so best way to get it to die is to remove all power sources for a few days/weeks and have it die out.
11/7/2010 12:03:50 AM • Sony VAIO... • Answered on Nov 07, 2010
My DVD rw (DW-Q58A) in VGN FS42w won't read CD
It happens if the lens becomes weak. I advice you get an external DVD-RW.
I hope you find this solution is helpful.
9/27/2010 2:33:35 PM • Sony VAIO... • Answered on Sep 27, 2010
3answers
I have an Vgn fs742w sony laptop, as of yesterday
Check your power supply, if the supply is good, then check the adaptor on the side of unit.
Do you have a power light when plugged in ?
Does the power supply have a light ?
Also you may try removing the battery and try to power up.
9/27/2010 1:58:26 PM • Sony VAIO... • Answered on Sep 27, 2010
Sony VAIO VGN-FS742/W Notebook Logo
71 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
vgnfs742w runs slow
  • Computers & Internet
