20 Most Recent
HP Pavilion zd7020US Notebook Questions & Answers
ZD7020US Display
sounds like you have the wrong monitor drivers installed, download updated monitor drivers from the manufacturer's website,
also check your display settings, as something is really wrong there.
I have an ASUS G51V that will not power up using
First u need to check if the power adaptor is working,
to check if the adaptor is giving the output power you may need to check what is the power output, normaly the output is in the range of 18 to 24 volts. You may use a multimeter to check it,else try connecting a torch bulb using two small wire one connected to the bottom the bulb and the other to the side point of the bulb, insert the other end of the wires to the small connector slots in the adaptor cable that goes into the laptop
Also check if it's properly connected to the slot in you laptop, there could be some connection problem
I need to physically open my zd7020us
Open the access panelUse the following steps to open the case:
WARNING:
The edges of metal panels can cut skin. Be careful not to
slide skin along any interior metal edge of the computer.
CAUTION:
This product contains components that can be damaged by
electrostatic discharge (ESD). To reduce the chance of ESD damage, work
over a noncarpeted floor, use a static dissipative work surface (such as
a conductive foam pad), and wear an ESD wrist strap connected to a
grounded surface.
NOTE:
If you need product model specific
graphics and instructions for opening the PC, search for a support
article that specifically pertains to your computer. In the Search field
(or Questions or keywords field) at the top of this page, type your
computer model number, a space, and the words "opening the case."
- Turn off the computer and unplug
all cables, except for power, and write down each cable location.
- Unplug the power cable and press
the Power
button.
- If
possible, move the computer to a clear, flat, stable work surface over
an uncarpeted floor.
- Remove
the panel retaining screws.
Figure 2: Screw locations
(your model might look different)
- Slide off the panel to expose the inside of the
computer.
Figure 3: Panel removal (your model
- If opening the case is difficult, search for a
support article that specifically pertains to your computer. In the
Search field (or Questions or keywords field) at the top of this page,
type your computer model number
the case
I have done something but i dont know what i did
In case using windows XP, right click on the empty space in the desktop and select Properties, Display Properties shall open up. Go to Appearance tab and click on the Advanced button. In the Item dropdown box select Window and make sure that color 1 is selected as White and Color 2 as Black.
Please rate this solution in case it works for you, it helps us in assisting users like you. In case the problem is still not resolved, do not rate thesolution, leave a comment instead and we shall assist you further.
Laptop won't power up without battery, needs 135W adapter
The ASUS power adapter is below spec and it may damage the adapter because the HP is drawing 45 W more power than it can deliver and will cause it to overheat.
The 17" HP requires 18.5 or 19 volts depending upon the model of the HP laptop (check the power requirements on the label on the bottom of the laptop). If the ASUS adapter doesn't deliver this voltage, it most likely won't power up the HP laptop.
Use the power supply/adapter from the other 15" HP. If this HP's adapter has a voltage output of 19 volts and the 17" laptop requires 18.5 volts, don't worry a voltage difference of 0.5 volts, the only problem is whether the power plug will fit into the power socket of the 17" HP laptop.
HP LCD Stripes
"Tab separation" on LCD board.
LCD NEEDS TO BE REPLACED.
One long beep and 2 short beeps
Depending upon your BIOS manufacturer, generally this POST error code means either a video card problem or a motherboard problem.
If the RAM is OK then you have a motherboard problem, and this may not be cost effective to fix. Consider putting your money towards a new laptop, remove the hard disk and put it into an external USB adapter case and use it as an USB hard drive for backup etc.
Cannot firnd bios password
try removing the CMOS Battery to reset the BIOS but make sure notebook battery and AC isn't attached it needs to be completly dead.
Display problems
Doesn't sound real good. Probably the LCD panel or driver chip. The chip is normally a part of the mother board. You might want to try reseating the LCD screen cable on both the LCD end and the motherboard end. That may resolve the problem. If not, try plugging in and external monitor. If you get a good display on that, you probably have a bad LCD, although there is still the possibility of the motherboard being bad.. If you don't get a good display on the external. you have a bad motherboard.
If you need
any additional information, please feel free to ask. If this information has
assisted you in the resolution of you problem, please return here to give my
assistance an appropriate final rating. If this information has answered your
question, and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
My top load washer will not agitate or spin,but the pump still pumps water out????
This may not strictly be a laptop computer question, but it sounds like the belt drive on the drum has broken or come off. This is a common problem. If you are handy, unplug the machine, turn it around, and remove the sheet metal screws on the back holding the back panel on. Remove that panel and look for broken or unseated belts. If you find broken or unseated belts, replace them with new ones. If you do not, you need to call in professionals or buy a new washer. Or find someone more handy to help. :>)
After I installed a new printer I cannot get online.
Do you have a firewall installed? If so, disable it and see if that helps.
Try a system restore, Start, programs, accessories, system tools, system restore. It will give you a list of dates to restore to. Put the latest date that you knew that you had a working connection.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
