20 Most Recent Kenmore 36 in.42741 / 42742 / 42744 / 42749 Electric Cooktop Questions & Answers
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
8/8/2014 5:57:44 AM • Kenmore 36... • Answered on Aug 08, 2014
0answers
What are the cutout demensions
their is a number in front of 42729 is it 110,106.564,363,or 991 ect
that is the source code and tells me if it was manufactured for sears by whilrpool,ge,frididaire,kitchen aid, ect ect ect
7/25/2011 3:28:01 PM • Kenmore 36... • Answered on Jul 25, 2011
2answers
Kenmore elite 36'' glass top cook top beeps and displays eo 11
so does mine
1/15/2019 10:42:07 AM • Kenmore Cooktops • Answered on Jan 15, 2019
Where can I order Decals for kenmore cooktop
Check out stovedecals.com - they offer Kenmore stove decals for your stove or cooktop.
12/29/2018 8:18:17 AM • Kenmore Cooktops • Answered on Dec 29, 2018
How do I unlock the cooktops on Kenmore Elite Electric Range model #C970-440935
Clear the lock mechanism -- as indicated by the DOOR LOC light -- by pressing and holding in the oven door light switch for 20 to 30 seconds. While the switch is depressed, the latch motor will gradually withdraw the lock, allowing you to open your oven door.
10/9/2018 10:09:24 PM • Kenmore Cooktops • Answered on Oct 09, 2018
I just installed a kenmore gas cooktop #32539. My connections are all good, but I smell gas! Seems to be leaking from inside the cooktop. New
Shut your gas off at the tank or meter valve. Open windows and doors and vacate. Call an appliance or gas technician!
7/12/2018 4:51:12 PM • Kenmore Cooktops • Answered on Jul 12, 2018
I have a Kenmore Elite Electric Range with Induction Cooktop #C970-440032 with an error code E074
Suggest down load the owners manual online and reference error codes.
3/21/2018 11:00:26 PM • Kenmore Cooktops • Answered on Mar 21, 2018
Gas cooktop Model 790.33233400
no body at fixya site will do anything you have to contact the service agent direct yourself to book a service
10/28/2017 10:37:22 PM • Kenmore Cooktops • Answered on Oct 28, 2017
Kenmore flat cooktop burners only provide low heat
Voltage check at plug or power panel
1/29/2015 6:22:35 PM • Kenmore Cooktops • Answered on Jan 29, 2015
Both parts of dual burner don't come on
Fuse or control
1/29/2015 6:16:45 PM • Kenmore Cooktops • Answered on Jan 29, 2015
Burner red light remains on
Do you mean safety light to let you know burner is hot?????
1/29/2015 6:14:36 PM • Kenmore Cooktops • Answered on Jan 29, 2015
Replacing wires on surface element switch(kenmore cooktop)..need to know where they hook up
Usually you can copy wiring from other element. Safest to consult wiring diagram found inside control panel.
1/29/2015 6:05:13 PM • Kenmore Cooktops • Answered on Jan 29, 2015
Two burners on right side do not heat
Check fuses. Burners are usually fused in pairs. Probably 2 fuses since 220V.(one for each 110 side of feed).
1/29/2015 6:03:11 PM • Kenmore Cooktops • Answered on Jan 29, 2015
Kenmore 36 in.42741 / 42742 / 42744 / 42749 Electric Cooktop Logo
Popular Tags
4 questions posted
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Cooktops
  • Kenmore Cooktops
Most Popular Question
problems kenmore 36 in radiant cooktops
  • Cooktops
