20 Most Recent
Kenmore 30 in.42731 / 42739 / 42734 / 42732 Electric Cooktop Questions & Answers
I need the wiring diagram and plug/receptacle
I believe that if you look on the name plate for the unit , it says that you will need a 30 amp, 220 volt supply circuit . This would be a two pole , 30 amp breaker , a run of # 10-3 cable with ground, and a junction box at the stove top location to make the splices. If you are going to use a plug connection, then a 30 amp 4 wire dryer outlet will give you the connection you need .
