20 Most Recent Cobra 200 GTL DX 4-Channels Base CB Radio Questions & Answers
Hi there, my cobra 200 gtl dx wont transmit on some frequencies. looses a few channels on each bank. It receives on all channels. This problem is intermittent. any ideas?
https://www.youtube.com/watch?v=a85zMM46Gi8 You watch this video and check your power output specially on those channel at chich not transmitting, if there is no power at those channel it mean that you program out of range radio band frequency, so you check your frequency and correct it.
5/22/2019 9:38:00 AM • Cobra 200 GTL DX... • Answered on May 22, 2019
Wiring a JCD-201M mic to my Cobra 200 GTL DX
Awesome. Check with these folks: Support Cobra Electronics Corporation easy-4xcgpgmbsyetxdvhu0rk3j02-4-0.png
2/4/2018 5:29:18 AM • Cobra 200 GTL DX... • Answered on Feb 04, 2018
Replacing Lamps in a Cobra 200GTLDX I need to
check the voltage going to the lamps before you do this so that you don't have to replace them . They might just be shorted enough to have the lights go out.
3/1/2015 9:00:22 PM • Cobra 200 GTL DX... • Answered on Mar 01, 2015
Sounds like you are on a different frequncey and
walk it over here and I'll fix it for you. turn the watts to 1.5 watts and check the frequency .
3/1/2015 8:24:28 PM • Cobra 200 GTL DX... • Answered on Mar 01, 2015
200 GTL DX Night glow face plate.
Icepick , there are diode in the radio to allow the voltage to flow to get those lights glowing. If the voltage is not at a specific level then you may have the problem you are describing. make sure you have 13.8 volts of power coming into the radio then check you voltage on T712 to make sure the voltage is ok also IC 5 . Check diodes 68 , 69, 71,72 for correct voltage . now you need a voltage chart. You will have to google it .
2/23/2015 2:26:16 PM • Cobra 200 GTL DX... • Answered on Feb 23, 2015
I need to know the price
I'll sell it to you for what ever you want to pay.
2/15/2015 11:20:39 PM • Cobra 200 GTL DX... • Answered on Feb 15, 2015
Cobra 1000 gtl no output
does the radio turn on at all ? Do you have it on cb not pa? Is your RF GAIN opened all the way? Squelch turned all the to the left?Volume opened about 1/2 way it should be on .if not go inside radio and look for VR that is beside the modulation transformer and turn it all the way to the right . If you have no power put put then you will have to adjust the power out put coil . you will need the service manual and some equipment to check this out. Its going to get expensive but if you feel as though you can't do it then take it to a tech and let them get the headache.
12/1/2014 1:36:36 PM • Cobra 200 GTL DX... • Answered on Dec 01, 2014
Cant get it to get on freq. ch 19 should be AM B
check your voltage its probably incorrect
11/2/2014 10:19:57 PM • Cobra 200 GTL DX... • Answered on Nov 02, 2014
Wiring JCD-201M to the Kenwood TS-2000.
9/7/2014 10:57:13 AM • Cobra 200 GTL DX... • Answered on Sep 07, 2014
Turn up power on cobra 200gtl
rv9 for hi power and rv8 for low.hi would be around 32 w and low around 4.
9/1/2014 3:26:04 PM • Cobra 200 GTL DX... • Answered on Sep 01, 2014
I have a lot of staic in my CB
yeah and so does everyone else.
9/1/2014 3:10:17 PM • Cobra 200 GTL DX... • Answered on Sep 01, 2014
My cobra 200gtl rev 2 cuts out on ssb after a few minutes
It sounds like the final transistor may be shorted/burned out. If you don't know how to locate or test the transistor you'll have to take it in to a tech. These transistors are usually quite cheap but as to the labour cost it depends on your tech. Usually what causes this damage is a bad antennae match or a bad antennae itself, even a shorted antennae cable. After you've repaired the radio check the antennae and cable first before connecting it up again, then check your match with an SWR meter. Good luck
4/19/2014 6:19:06 PM • Cobra 200 GTL DX... • Answered on Apr 19, 2014
Cobra 200 gtl dx only does 12 watts on high
Open radio up and adjust rv9for am fm high power or rv 14 for ssb for high power,do not use a screwdriver,a matchstick would be better.board information is available from cb tricks.com
3/25/2014 9:31:46 AM • Cobra 200 GTL DX... • Answered on Mar 25, 2014
Cobra 200gtl High Power Transmit problem??
Depending on the type of power supply, radio frequency (RF) energy from the transmitter may be 'fooling" it into thinking that you're overloading it. Check to see if there's any discernible dimming of the meter lamp when this problem occurs, if so, the supply is the culprit.
Otherwise, its probable that the final amplifier transistors are overheating, either they are 'leaky' or not properly attached to the heat sink.
3/23/2014 1:56:27 PM • Cobra 200 GTL DX... • Answered on Mar 23, 2014
2answers
Talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
http://www.cbtricks.com/radios/cobra/150gtl_dx/tsb/cobra_200gtl_dx_tsb_10041.pdf
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at [email protected]. I look forward to hearing from you.
Dean
Rollin CBs
Mt. Vernon, TX
2/11/2014 12:02:00 AM • Cobra 200 GTL DX... • Answered on Feb 11, 2014
Will not key up 200 gtl dx nightwatch
try a different mic . your mic may have a broken tx wire.
10/30/2013 6:37:41 PM • Cobra 200 GTL DX... • Answered on Oct 30, 2013
CLARIFIER MODS.NEED TO ALLOW CLARIFIER TO SIDE DOWN 5 KCS
http://www.cbtricks.com/ if its not there it cant be done
6/10/2013 11:11:01 PM • Cobra 200 GTL DX... • Answered on Jun 10, 2013
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
70 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
get operating manual cobra 200
  • Radio Communications
