20 Most Recent
Casio FC-200V Scientific Calculator Questions & Answers
How to solve matrix
What do you mean by "solve matrix"? Do you want its determinant? Its inverse? The eigenvalues and eigenvector? Solve a system of linear equations?
Where can i find the log key in casio FC-200v
There isn't one. You can calculate the common log by using the relationship
log(x) = ln(x) / ln(10)
That is, calculate the number's natural log and divide it by the natural log of 10. The natural log is the shifted function of the 8 key.
Rounding off in Casio FC 200V
Press [SETUP] select FIX then press [EXE]. Enter the number of decimal digits you want (3 or 4). Press [ESC] then press [EXE]
Hope it helps.
Fc 200 calculator
The functions are many, and the only way to master them is to have the user guide for the calculator ready at hand. Read sparingly, focussing on the problem at hand. By constant practice you will soon use it as pro.
Here is the
link to the calculator's guide.
Hope it helps.
Casio calculator fc-100v, to the power of?
Hello
To calculate a number to an arbitrary power you use the button labeled ^ .
If you want the cube of 2 your enter
[2][^][3] will give you 8. If your exponent is negative use the sign change key (-) and close the negative exponent between parentheses : for exemple the sequence to compute 2 to power of negative 5 is as follows
2[^] [(] 5 [(-)] [)] which means you enter the value of the exponent before the change sign (-). If you use the big MINUS sign you will get a syntax error.
Hope it helps.
