20 Most Recent HP Broadcom NetXtreme Network Adapter Questions & Answers
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
HP Broadcom... | Answered on Apr 09, 2012
Check the hp website they usually will have all drivers for things that are compatible with an hp computer along with products that they create. If it is not found on there try www.downloads.cnet.com.
HP Broadcom... | Answered on Oct 23, 2010
Your windows are corrupted.
Install new windows for your laptop.
ENJOY...
HP Broadcom... | Answered on Oct 17, 2009
The Broadcom driver maybe corrupted on got uninstalled. Reinstall the Broadcom driver.
HP Broadcom... | Answered on Aug 11, 2009
install from the cd u hv purchased ur lan card
HP Broadcom... | Answered on Jan 31, 2009
Restart your computer in safe mode. Press F8 while rebooting. Once in safe mode, go to Start - control Panel - system. Right click on and remove the network card devices (you might see more of them there than you do in normal mode). Then restart the computer.
It should detect the new card and allow you to install the drivers for it. If it still doesn't detect the new NIC card, try powering off the machine. Open the case, and make sure the card is properly seated inside the computer case. Press down on it firmly. Then restart and see if it detects the card.
If it doesn't detect the card, the card might be bad. If you have another card, I'd suggest trying a different one, to see if it recognizes a card that you know is good.
Try these things and let me know how it goes. Thanks.
-Asaph
HP Broadcom... | Answered on Jan 21, 2009
Make sure the light on your cable modem that represents your connection to the computer (it might be marked LAN, Ethernet, or PC) is lit up and isn't flashing. The light will tell you if your network card is properly connected to the cable modem.
If the light isn't on, make sure you've connected the wire to the right port on the cable modem, and try restarting the cable modem by unplugging it, wait 30 seconds, and plug it back in.
If it still doesn't work after that, contact your Internet provider. Their technical support department can help you get it set up.
HP Broadcom... | Answered on Dec 10, 2007
Check with the LG website for support
If you supply details about your laptop and operating system it should be able to help
http://www.lge.com/support/main.jhtml
HP Broadcom... | Answered on Dec 07, 2007
HP PRINTER PRINTER TeCH SuPPoRT pHoNe [!] {\188867O*O271*] nUmBeR KBl USA
USA tech support for HP PRINTER printer, Dial HP PRINTER Printer Tech.nical Support Phone Number +1-888-67O.O.2.7.1. regarding with the HP PRINTER printer, if you are facing any glitches with printer like troubleshooting, Driver installing. They provide the best technical support to the USA customer at anytime whenever you want. Their service will be available 24&7 hours in 365 days. http://printertechnicalhelp.com/HP PRINTER-printer-technicalhelp.html
HP Computers &... | Answered 9 hours ago
HP Broadcom NetXtreme Network Adapter Logo
Popular Tags
9 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
lost local
  • Computers & Internet
