20 Most Recent Honeywell HFD-120 Air Purifier Questions & Answers
If it is new enough it could be due for a warranty replacement. Otherwise, there could be an open fuse or a failed switch.
Honeywell... | Answered on Nov 29, 2014
Honeywell does not have any serviceable parts. Get a new one.
Honeywell Air... | Answered on Oct 24, 2018
Are you really unscrewing it? (to the left)? If not, then perhaps put a hammer handle on the handle at the outside rim and thump the hammer with the palm of your hand..
Normally Honeywell has NO replacement parts. Run it as is, then throw it away.
Ignore the lights. Wash the outer foam filter every two months. As long as air is going through the inner filter does not need to be changed. Blow the inner filter out FROM THE INSIDE with your vacuum cleaner. (blow air the opposite direction of air flow to get the nasty stuff off.)
Your air purifier most likely is fried.
Honeywell Air... | Answered on Feb 26, 2018
The identification label on the unit probably specifies operation on 115v.
Honeywell Air... | Answered on Jan 17, 2018
am sorry to disappoint you, once this condition is reached, it means the motor windings have overheated and your motor needs to be replaced, This is the only best thing to do to rectify this situation. This indicates that the insulation covering the wire used to make the winding of the motor has been cooked by the overheating and it is shorting out ,THIS WILL CAUSE THE MOTOR CATCH FIRE.
Please unplug the unit and have the motor replaced or buy a new unit for your safety.
Honeywell Air... | Answered on Oct 20, 2017
Honeywell HFD-120 Air Purifier Logo
7 questions posted
Top Honeywell Air Purifiers Experts
Bill Long
jdthefixer
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Air Purifiers
Most Popular Question
new honeywell hfd 120 purifier will not
  • Air Purifiers
