20 Most Recent HP Pavilion dv8000z Notebook Questions & Answers
2answers
What are those lights on
Ok check your connections first the light blinking is the disk activity the other one is the power. Check your monitor at menu and see what input is selected. Select the correct input you are using for your graphics ex: hdmi, vga, .... etc
10/18/2017 11:16:09 AM • HP Pavilion... • Answered on Oct 18, 2017
2answers
I have an older HP Pavilion dv8000z (ES184AV) PC
You can format the full hard disk and create new partition when installing windows os.
3/11/2017 1:14:24 PM • HP Pavilion... • Answered on Mar 11, 2017
2answers
Broken lcd screen, who ,how, make deliveries to east europe?
Consult HP service centre in your area.
http://www.hp.com
9/10/2014 4:20:02 PM • HP Pavilion... • Answered on Sep 10, 2014
6answers
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
12/18/2013 1:11:50 AM • HP Pavilion... • Answered on Dec 18, 2013
Internet radio sounds slow + distorted
Shut down/Disable all add-on on browser, Toolbars etc. Close all programs that are not needed, on the machine. Could be the website?
11/25/2012 10:04:47 PM • HP Pavilion... • Answered on Nov 25, 2012
Bluetooth connection issues
There are several things to try:
Remove and then reinstall the device:
Click the Start Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Select the device that's not working, and then click Remove.
Click Add, press the reset button on the device
(or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
If the device is not found, repeat the previous step.
When the device is found, select it, and then click Next.
Follow the rest of the instructions in the wizard.
Make sure the device is turned on and that the batteries don't need to be replaced.
Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable.
If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
Make sure that you installed the device using the correct program. If not, reinstall the device.
For a printer, follow these steps:
Open the Add Printer wizard by clicking the Start Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
For a mobile phone, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Click Add.
For a keyboard or mouse, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Connect a wired keyboard or mouse to your computer.
Click Add.
The device might be out of range of your computer, or too close.
Try moving it closer or a little farther from your computer.
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.htmlRuns in the background, and monitors the activity of Bluetooth devices around you
10/6/2012 11:30:57 PM • HP Pavilion... • Answered on Oct 06, 2012
How do i reset my hp pavilion dv8000 to factory
Hi,If your data backed up, you can restore the machine to factory settings byusing their utility which I believe installed and you need to hi a keycombination or a Key to start the process of resetting it to factorysettings!By press F11 at startup you will be able to start the restore option, bewarned you will lose all programs/applications installed extra on thismachine.Using the PC Recovery Solutionhttp://h10025.www1.hp.com/ewfrf/wc/d...rod uct=18703Maintenance and Service Guide:http://h10032.www1.hp.com/ctg/Manual/c00701888.pdf
12/8/2011 7:24:58 AM • HP Pavilion... • Answered on Dec 08, 2011
2answers
HP Pavillion d9500....Battery not charging
First thing I would suggest is to test the charger with an electronic meter. Ensure you set it on DC and test if there is a constant power coming from it. For example, say it has an output of 14 volts DC, check if the flow is constant. If is not then you have a faulty charger. The next steps will be further complicated which I will not cover in this solution. I hope this helps you and good luck.
8/20/2011 5:02:49 PM • HP Pavilion... • Answered on Aug 20, 2011
I get a 0211 Keyboard
Do you have a BSOD screen? blue screen pops up then laptop shuts down?
3/9/2011 11:56:09 PM • HP Pavilion... • Answered on Mar 09, 2011
My touchpad on my hp
Visit hp and find the newest driver
Here: http://welcome.hp.com/country/us/en/support.html
2/16/2011 8:55:59 PM • HP Pavilion... • Answered on Feb 16, 2011
0answers
2answers
Touchpad doesn't work on HP Pavilion DV8000 laptop
My HP dv9000 has exactly the same problem and it has never been opened since delivered new. The problems started a couple of weeks after I received it and got progressively worse.
11/26/2010 7:38:31 AM • HP Pavilion... • Answered on Nov 26, 2010
Hi. i lost my sound on hp dv 8113 cl few days ago
  • Hi, the best thing to do at this point is perform a "System Restore." Try to remember the exact "Date before the problem occur, or once you start the System Restore, ("pick a date going back more than 5 days"), check the dates and see if any of the dates seem familar. Pick the closest date prior to the "Sound going out!" Type in the "Search Window" from the start menu: system restore; scroll to find, and open. Follow all the instructions carefully for the process to be successful. "Hope it works out for you; if so rating the help will let me know, thanks."
4/26/2010 1:44:07 AM • HP Pavilion... • Answered on Apr 26, 2010
10answers
Hp pavilion dv8000 help
Find out how to open up your computer youself and where the wires run from your ac power plug to motherboard has a little socket it plug. sounds like it is not connected. lol, free advice. Just plug it in
4/17/2010 1:40:21 AM • HP Pavilion... • Answered on Apr 17, 2010
Log on message the system could not log you on. make sure your..L
change log to this computer in place of domain
3/27/2010 4:07:56 AM • HP Pavilion... • Answered on Mar 27, 2010
I can't get BIOS in my dv8000? One day just
Does your Hard drive indicator flicker? OIf so, try connecting an external monitor.
2/10/2010 8:28:59 PM • HP Pavilion... • Answered on Feb 10, 2010
My HP pavilion dv8000 gets stuck on the start up
hello dbudnick,,,were you able to solve your hp8000 'start up' problem?
mine was experiencing the same issue....
the method of removing the batt ,,then pressing the on button for
30 sec ,,or more,,,doesnt seem to help....however,,,,sometimes
the pc wont even even get to the Micsoft bootup screen.,,but rather
stall the <F8> or <F10> press DOS Screen..
gpalm
12/22/2009 9:37:26 PM • HP Pavilion... • Answered on Dec 22, 2009
Is there an antenna inside the hp note book
These laptops are hit and miss wirelessly to tell the truth. Take the wireless card out and make sure the antenna is attached to the card properly. You will see the two wires. Often times one fo these connections is broken. If so reattaching the antenna will solve the weak connections.
11/8/2009 3:10:33 AM • HP Pavilion... • Answered on Nov 08, 2009
HP Pavilion dv8000z Notebook Logo
79 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
  • Computers & Internet
