20 Most Recent
Kenmore Freezer 13.7 cu. ft. Upright Freezer Questions & Answers
I have a Kenmore Frostless Model #: 253.21041104
Best thing to do first is get a thermometer to be sure the temperature is correct. Items still freeze at higher temperatures. If you have ice cream and it is soft, then you have a temp problem.
The high temp light is on. What can I do to reset
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power fails, the alarm will not perform.
An ON/OFF switch allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the freezer door to
view the alarm switch. The freezer is shipped with the switch in
the OFF position.After the freezer has run longenough to
lower the temperature, you may set the switch to the ON
position.
• To activate the alarm, set the switch to the ON position.
• To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
Where is the 9V battery located on a Kenmore upright freezer model 970
The location of the 9V battery on a Kenmore upright freezer model 970 can vary depending on the specific model and design. However, in general, the 9V battery is typically located in the control panel or on the back of the freezer near the compressor. You may need to consult the freezer's manual or contact Kenmore customer support for more specific information regarding your model.
