20 Most Recent Philips 9400i Handheld Digital Voice Recorder Questions & Answers
Go to www.philips.com
Philips 9400i... | Answered on Apr 27, 2014
Connect it to your Mac and refer to User Manual.
Philips 9400i... | Answered on Apr 26, 2014
Time to send it to Phillips for service or get a new recorder,definite internal component failure
Philips 9400i... | Answered on Apr 07, 2010
You need to check the file format on music, windows media play does not support their format ((*.ra, *.rm). You can change the format to mp3 or .wav using other software.
Philips Audio... | Answered on Aug 24, 2019
I have a multimedia speaker DSP 3300.but I haven't the remote .Is there any way to operate it.
Philips Audio... | Answered on Jul 16, 2019
Google (Philips)(DVT1250)(manual) without parens.
Philips Audio... | Answered on Jul 04, 2019
What is the format of the drive? The Philips HTS6510 can only read USB drives that are formatted as FAT16 or FAT32. It can't read files from an NTFS drive. NTFS is the "new file system" for Windows but dates to Windows NT/Windows 2K or so. This is the default format for larger capacity USB drives since more files can be added per folder. See page 51 of the manual for the Philips HTS6510 for the file format specifications for USB drives.
If the file format is FAT16 or FAT32, try a different USB drive and check the current drive in another device. The USB drive may be damaged or may have lost the data it needs to find the files. All flash memory can fail with no warning. Replace a faulty drive. Alternatively, the USB port on the HTS6510 could be damaged. This can happen if too much current flows through the port. If the port is damaged, I don't recommend having the unit repaired unless it is under warranty (1 year). Copy your files to a CD and listen to the music or view the images from that media. The overall cost will be lower.
Philips has the manual on the product support page: https://www.philips.co.uk/c-p/HTS6510_05/-/support . The current link to the manual is https://www.download.p4c.philips.com/files/h/hts6510_05/hts6510_05_dfu_eng.pdf .
I hope this helps.
Philips Audio... | Answered on May 28, 2019
????? ??????? model name:SP050????
Philips Audio... | Answered on May 16, 2019
all these things are deleted through menu setting etc.
Philips Audio... | Answered on May 15, 2019
Hello Nicholas, it would be nice if you commented that audio signals are connected to your Soundbar, in this way I could find the possibility of failure, to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Nicholas, seria bueno que comentes que se?ales de audio tienes conectado a tu Barra de Sonido, de esta manera podre buscar que posibilidad de falla, para buscar la mejor solucion posible
Espero tu respuesta
Saludos Franco Dosil
https://data2.manualslib.com/pdf5/110/10927/1092650-philips/hts8100.pdf?c627f1691eabddb18405d1975afcf790&take=binary
Philips Audio... | Answered on May 08, 2019
Philips 9400i Handheld Digital Voice Recorder Logo
Popular Tags
9 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
download driver free
  • Audio Players & Recorders
