20 Most Recent
Honeywell HWM-450 4 Gallon Humidifier Questions & Answers
Question for the HWM-450 4
get a better brand as 2 failures of the same brand indicate design faults
report the matter to the manufacturers engineering department and ask questions as to why the failures occur
1/26/2018 8:32:18 PM •
Honeywell...
Answered
on Jan 26, 2018
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
2/11/2015 3:57:01 PM •
Honeywell...
Answered
on Feb 11, 2015
Need replacement o-ring for water tank cap
This is a posting from someone other than myself...however, it presented a good solution.
A solution to the problem with the fill cap failing/leaking. It was/is not the cap, it's the gasket/grommet/o-ring. Remember "THE MAGIC BULLET", well the gasket, that's where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Recommended:
Yes
Amount Paid (US$): 45.00
Battery Life: N/A
Noise Level: Almost noiseless
12/28/2010 10:46:28 PM •
Honeywell...
Answered
on Dec 28, 2010
Brand new and not running
Solutions:
Unit is out of water Refill and reinstall Water Tank
Humidity level set too low Reset humidity to a higher level
Unit is too hot Turn off the power and let the unit cool down
Power Unit is not installed Reinstall Power Unit
properly
Unit is not set on level Place the unit on a firm, flat, and level surface
surface
There is too much moisture Turn off the power and completely dry out the unit
inside the unit
Unit is not running, no lights Unit is off due to timer Press Power button
Power unit is not Reinstall Power unit
installed properly
Power outage Press Power button
Humidity level was set but Humidity level set too low Reset humidity to a higher level
unit start
These are the basic steps that should be taken per Honeywell. Let me know the results.
3/30/2010 12:12:46 PM •
Honeywell...
Answered
on Mar 30, 2010
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT
2/22/2010 8:32:28 AM •
Honeywell...
Answered
on Feb 22, 2010
Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
1/18/2009 10:43:16 PM •
Honeywell...
Answered
on Jan 18, 2009
Honeywell HE200 humidifier only runs when fan/heat are off
It sounds like the wiring for the humidifier may not be correct. The solenoid valve, which controls the flow of water to the humidifier, should be wired to the humidistat and the transformer, not to the furnace or fan. It is possible that the bottom wire of the solenoid is connected to the wrong terminal on the transformer or humidistat, or that the top wire is connected to the wrong terminal on the humidistat. I recommend consulting the installation instructions for your specific humidifier model, or consulting a professional HVAC technician to verify the correct wiring.
1/22/2023 4:38:56 AM •
Honeywell...
Answered
on Jan 22, 2023
High-pitched noise from Honeywell Humidifier
Sounds like the high pitched noise is coming from the solenoid valve which allows water to enter the humidifier. Typically when the water pressure is too high, it causes this high pitched sound at the solenoid valve. You can adjust the water pressure a little at a time and see if it helps, just make sure you’re getting enough water across the water panel.
1/6/2023 9:16:59 PM •
Honeywell...
Answered
on Jan 06, 2023
