20 Most Recent Kenmore 24 in. 16193 Stainless Steel Built-in Dishwasher Questions & Answers
6answers
Flashing green light and not starting
dott, Im looking at the tech sheet for your model and it gives no information on the flashing light. It has been my experience that this usually indicates a bad touchpad. Since this is under warranty, it will be covered 100%. A couple of things you can try, first kill the power to the unit for 1 minute and see if it comes back the same way. If that doesn't work try to press the heated dry and start/cancel pads together for 3 seconds with the dial set to rinse only. This would put the unit into a test cycle. If both of these fail, you probably have a bad touch-pad. Call for service...Catriver...post back.
4/24/2010 6:25:03 PM • Kenmore 24 in.... • Answered on Apr 24, 2010
Dishwasher doesnt spray the dishes and it no longer drains
It sounds like your jet sprays are clogged. Try a couple of things. Lets start by cleaning the unit with beach and white vinegar. Use a cup of each with not dishes inside. Do not heat dry, ever. Next use a liquid jet cleaner. You should notice a difference doing this. Hope this helps. Let me know if I can help you with anything else.
JimmyC
9/30/2009 5:42:01 PM • Kenmore 24 in.... • Answered on Sep 30, 2009
My kenmore washing machine fills with water but
Often these work by reversing the motor which has two pump impellers. One direction will pump the water out and the other will pump it through the spray bar. IF the one pump impeller has broken then that would explain your symptoms.
If this is the type you have, verify that the motor is running reversed from when it is draining. If it is not running during wash time, then the timer is probably at fault. If it is running, check for broken pump impeller for the was direction.
9/29/2009 6:24:31 AM • Kenmore 24 in.... • Answered on Sep 29, 2009
My older built in Kenmore 3380957 Rev.A dishwasher.
If it is doing when it is washing, then it likely to be a problem with the pump, but it might just be 'hunting' because the filters are partially blocked. There is the filter that you can see easily, but there is a fine filter underneath that blocks with fine grey lint. Water left in the bottom can be caused by that because the drain pump is past the filter and is on a timer. https://www.google.com/search?q=Kenmore+3380957 ..
3/2/2024 4:32:03 AM • Kenmore... • Answered on Mar 02, 2024
Hinges are very noisy when opening or closing door of my Kenmore dishwasher model 587.1527. What can I check to resolve problem?
To open the Kenmore World class dishwasher, follow these means:
Press-and-hold down the "Sani-Wash" button for somewhere around three seconds until the showcase screen counts down from three to nothing. The red "Lock" Drove ought to now douse and you ought to now have the option to get to each of the buttons on the control center.
10/14/2023 9:30:27 PM • Kenmore... • Answered on Oct 14, 2023
E:31 on Kenmore Elite 630.13902013 dishwasher
9/8/2023 6:35:19 AM • Kenmore... • Answered on Sep 08, 2023
Kenmore dishwasher model 587 has ERR code and lights flashing.
If you're experiencing an ERR code and flashing lights on your Kenmore dishwasher model 587, it indicates an error or fault in the dishwasher's operation. Unfortunately, without specific details about the error code or which lights are flashing, it's challenging to provide a precise solution. However, you can try the following troubleshooting steps: 1. Check the owner's manual: Refer to the dishwasher's manual for a list of error codes and their meanings. It should also provide troubleshooting steps specific to your model. 2. Power cycle the dishwasher: Turn off the dishwasher by unplugging it from the power outlet or shutting off the circuit breaker that supplies power to it. Leave it disconnected for a few minutes to ensure a complete power cycle. Then, plug it back in or switch the circuit breaker back on. 3. Check for obstructions: Inspect the dishwasher's interior, specifically the spray arms, filters, and drain pump, for any obstructions such as food debris or foreign objects. Clean or remove any blockages that you find. 4. Run a diagnostic cycle: Some dishwashers have a diagnostic mode that can help identify the cause of the error. Refer to the manual for instructions on how to initiate the diagnostic cycle. 5. Contact customer support: If the issue persists or you are unable to determine the cause of the error, it's recommended to reach out to Kenmore customer support or a qualified appliance repair technician. They will be able to provide further assistance and help resolve the problem. Remember, the specific steps and options may vary depending on your dishwasher model. Consulting the owner's manual is always the best course of action when troubleshooting appliance issues.
6/21/2023 3:34:15 AM • Kenmore... • Answered on Jun 21, 2023
What year is my dishwasher manufactured s/n F24221277
By the serial number provided, this KENMORE product was manufactured October 2012. Best to you.
6/12/2023 4:18:36 PM • Kenmore... • Answered on Jun 12, 2023
Kenmore Ultra Wash seems like not heating water
5/30/2023 6:19:08 PM • Kenmore... • Answered on May 30, 2023
2answers
Kenmore Elite model 630.17303401. Inconsistent issues with running after cycle and...
Unfortunately, that sounds like a control board issue, although if you are lucky, it is just bad connections _to_ the control board. They are expensive so need correct diagnosis by a tech. Then you get warranty on the parts and the job.
3/14/2023 1:02:44 AM • Kenmore... • Answered on Mar 14, 2023
What year is my Kenmore Ultra Wash dishwasher? Model # is 665.1591680. I'd like to find a manual as well.
Question edited for clarity, 'Manuel' is the name of a Spanish gentleman, a 'manual' is what you want. :>D June 1999 possibly. Dates are decoded from the Serial Number. This is the closest manual it is a 655 series 159****
Kenmore 665.15989 Manuals - ManualsLib
ManualsLib https://www.manualslib.com > ... > Dishwasher We have 1 KENMORE 665.15989 manual available for free PDF download: User Manual. KENMORE 665.15989 User Manual (25 pages). https://www.google.com/search?q=665.1591680+date+of+manufacture ..
3/11/2023 9:26:11 PM • Kenmore... • Answered on Mar 11, 2023
2answers
This is my Kenmore dishwasher serial number: F24830624. Can someone tell me how old it is?
February 2004. To determine the age of your appliance, use your serial number (not model number) to find date of manufacture. Kenmore serial numbers begin with two letters followed by six numbers. The 2 letters at the beginning of the serial number tell you the month and year it was made. Jul 13, 2021
How old is my Kenmore 110 model 82682110? - iFixit
3/4/2023 10:38:19 PM • Kenmore... • Answered on Mar 04, 2023
2answers
Dishwasher isn't filling with water
It sounds like your Kenmore dishwasher is having an issue with water not filling up in the tub. There could be a few different reasons why this is happening. One possibility is that the dishwasher's water inlet valve is malfunctioning. This valve controls the flow of water into the dishwasher and if it's not functioning properly, it could be preventing water from entering the tub. You may need to replace the water inlet valve in order to fix the issue. Another potential cause could be a clogged or dirty filter screen or spray arm. If these parts are not working correctly, it could be causing the water flow to be disrupted, which could lead to the dishwasher not filling with water. Cleaning or replacing these parts could solve the issue. It's also possible that there's an issue with the dishwasher's float switch. This switch is responsible for monitoring the water level in the tub and if it's malfunctioning, it could be causing the dishwasher to stop filling up with water. You may need to replace the float switch to fix the issue. Finally, there could be a problem with the dishwasher's control board or timer. If these parts are malfunctioning, it could be causing the dishwasher to stop filling with water or not complete a cycle. In this case, you may need to replace the control board or timer to fix the issue. It's recommended to check these potential causes one by one until you identify the root cause of the problem. If you're not comfortable doing this yourself, you may want to consider contacting a professional appliance repair technician to help you diagnose and fix the issue.
2/18/2023 1:50:52 PM • Kenmore... • Answered on Feb 18, 2023
Kenmore dishwasher model 630.12303314 displays error code E21. What does it mean?
Hello You try this it may help. How do I fix error code E21 dishwasher?") Circulation Pump Blocked
  1. Remove any excess water before removing the base of the machine to release the pump.
  2. Check and remove any blockages preventing the circulation pump from turning and Replace if any damage is found.
1/10/2023 4:23:05 PM • Kenmore... • Answered on Jan 10, 2023
My kenmore dishwasher model 665.13032k112 has been going to error mode at start
Please try to reset, plase check the link https://www.youtube.com/watch?v=v1by_MtVQJY
12/8/2022 3:37:34 PM • Kenmore... • Answered on Dec 08, 2022
KENMORE ULTRA WASH II MODEL 665.1675590, WATER IN BOTTOM. JUST LOUD CLICK WHEN TRY TO START NEW CYCLE?
It could be a few things, faulty door lock, stuck water inlet valve, faulty control board. You need a service call to diagnose and fix. There are some ideas in the link. https://www.google.com/search?q=KENMORE+ULTRA+WASH+II+MODEL+665.1675590%2C+WATER+IN+BOTTOM.+cycle+not+starting Please don't type in all CAPS, it is considered SHOUTING, is rude and also difficult to read. Thanks
11/29/2022 5:30:35 PM • Kenmore... • Answered on Nov 29, 2022
Kenmore 24 in. 16193 Stainless Steel Built-in Dishwasher Logo
6 questions posted
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
flashing green light not starting
  • Dishwashers
