20 Most Recent KitchenAid KHWS02R Front Load Washer Questions & Answers
Washer is making noise & barrel seems loose
Broken or unhooked spring ?
5/4/2014 5:38:53 PM • KitchenAid... • Answered on May 04, 2014
0answers
F11 error code
Be the first to answer 1/16/2014 12:00:46 AM • KitchenAid... • Posted on Jan 16, 2014Be the first to answer
0answers
Control lock
Be the first to answer 12/19/2013 7:38:21 AM • KitchenAid... • Posted on Dec 19, 2013Be the first to answer
Start button loose
check the installation or replace it with new one
12/9/2013 10:26:00 PM • KitchenAid... • Answered on Dec 09, 2013
0answers
Error code 06
Be the first to answer 6/10/2013 2:55:14 AM • KitchenAid... • Posted on Jun 10, 2013Be the first to answer
0answers
F21 Error Code
Take a look at this document.
11/2/2012 2:09:38 PM • KitchenAid... • Answered on Nov 02, 2012
Lock out
First of all, thank you very much for choosing FIXYA today for your online technical support needs.See page 12 of the User's Manual for detailed instructions on how to operate the CONTROL LOCK feature on that appliance.Basically to unlock the controls just press and hold the CYCLE END SIGNAL button for 3 seconds until the CONTROL LOCKED status light turns off. Here is a direct link to the ONLINE USER'S MANUAL for that model:http://www.ajmadison.com/ajmadison/itemdocs/ka_import_8182400.pdf To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual. You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer. I truly hope that was helpful to you. Good luck and take care. Joe.
1/16/2012 12:00:41 AM • KitchenAid... • Answered on Jan 16, 2012
My washer fills with water while not running
You will need to replace the hot/cold water inlet solenoid. IF the water is flowing into the washer, when the washer is off, the gasket is damaged in the solenoid OR the solenoid has failed. This should fix your problem.Appliance Parts house should have the part, turn water off and unplug from electricity - remove hoses (catch water with pan), should have about three screws holding it to the body of the machine. remove from machine mount, remove wires, one at at time and remount to new part, install new solenoid to body of washer, reassemble case, replace hoses, plug in, and test. Should fix problem. I would suggest replacing hose washers, while you have the hoses off from the back of the machine. May leak from there next, if not replaced.Hope this helps...
1/7/2012 5:37:41 PM • KitchenAid... • Answered on Jan 07, 2012
Water did not drain all the way out after last wash. Washer is now flashing F 06
the machine tined out on the pumping out thats fault 06 you have a blockage could be your filter / pump / outlet hose / sump hose / drain hose start with the filter
11/26/2011 11:00:31 AM • KitchenAid... • Answered on Nov 26, 2011
The machine starts then stops a few minutes into
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
8/1/2011 6:16:08 PM • KitchenAid... • Answered on Aug 01, 2011
We have had this washer
I'm sure all the happy helpers on this forum agree with you but it doesn't matter what make and model it is (this FixYa independant forum tries to answer for all makes and models) smells happen ;-0(
Also I'm sure you don't have to spend money on a particular 'cleaning' product; that's just a ploy from your manufacturer. Let's try to assist ;-0)
Bad odours could be coming from a few places.
  1. the plumbing u-bend or
  2. the fact that there is 'foul' water being left in the drum.
  3. No washes at 90 degree+ !
I would suggest checking the plumbing u-bend for trouble first, then following the notes on checking and cleaning the drain filter and the drain pump to ensure there is nothing 'obnoxious' hanging around the two of them! Finally run the occasional 90+ wash to kill bacteria.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
7/16/2011 4:07:14 PM • KitchenAid... • Answered on Jul 16, 2011
KitchenAid KHWS02R Front Load Washer f11
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
3/11/2011 8:55:36 PM • KitchenAid... • Answered on Mar 11, 2011
KitchenAid KHWS02R Front Load Washer Logo
67 questions posted
Top KitchenAid Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Washing Machines
Most Popular Question
washer fills water while not running
  • Washing Machines
