20 Most Recent
Bosch WFMC 2100 Front Load Washer Questions & Answers
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Wfmc1001 no wash, no spin,
Make sure the door gets locked then verify if the motor hums when the relay on the motor controller clicks. Check the resistance/continuity of the motor windings through the carbon brushes and the continuity of the motor wire harness if the motor doesn't hum. Make sure the wier harness is intact and the connectors are clean and snug fit. Replace the wire harness if necessary or the motor controller if the wire harness, the motor windings are all good and the motor doesn't hum at all. Replace the motor if it just hums or if the windings are open.
I have a Bosch WFMC2100UC101 washer that just
Its possible you have a blocked drain closer to the tub. Try tilting the machine to access underneath the machine and locate the drain pump. Then have a basin read to catch any water and remove the hose that goes from the pump to the drum and check for anything that may restrict water flow, possibly a sock. Hope this helps.
Spin cycle will not engage ..
The machine is failing to empty completely, make sure drain hose is free to drain and the drain is not blocked and that the filter isn't blocked. Also make sure you haven't selected rinse hold
regards
O2 xda 2 mini application installation
There can be three types of applications that you download from freeware sites:
- '.cab' files, that can be directly installed from your PPC
- '.exe' files, which are direct to be run applications that need no installation, just have to be placed in any folder and a shortcut has to be placed in the start-menu.
- '.exe' setup files. These files have to be opened in your PC while having your PPC connected thru Active Sync. This will install the application to your PPC thru your PC. These should be the kind of applications that you might be talking about for which you get such an error message "Not a valid PPC application!"
I think this should have solved your queries regarding PPC applications.
If this really solves your problem, Please Rate...
Borch wfmc2100 watersoftner not draining
this is joyce
This will happen, I also have a front loader machine it also does this I just empty it out and start over every time. the water pressure is so strong that it leaves some in resorvor.
thanks
joyce
E04
Perhaps try opening the round panel on the front of the machine at the bottom and cleaning that hose...good luck because it might be messy.
Bosch lr30 receiver not turning on
Potential causes and fixes:
Battery Terminal Corrosion:
Cause: If your Bosch laser receiver has been submerged in water, the battery contacts and sometimes the circuit board may have corroded.
Fix:
Remove the batteries and clean the battery terminal contacts.
Pry open the bottom cover and clean any corrosion on the circuit board.
Calibration Issues (for Bosch GLL 2-20):
Cause: Dropping the Bosch GLL 2-20 can lead to misalignment and errors.
Fix:
The best way to address this problem is to calibrate the laser level.
You can either contact the Bosch service center or follow the calibration instructions in the manual.
General steps for calibrating a laser level with a misaligned pendulum:
Remove the screws and outer cover.
Locate the pendulum hanging in its stationary position.
Remove the glass window of the laser level.
Adjust the stationary position of the hanging pendulum using the main adjustment screw.
Fine-tune right-left adjustments using other smaller adjustment screws.
Reassemble the laser level.
Cracked Glass Lens (for Bosch GLL 2-50):
Cause: If the horizontal glass lens is cracked, it affects accuracy and safety.
Fix:
Unfortunately, this problem is often unrepairable.
It's advisable to replace the laser level to ensure safe operation1.
Remember to lock your laser level when not in use or during transportation to prevent pendulum movement1. If these steps don't resolve the issue, consider reaching out to Bosch for professional assistance or repair
