20 Most Recent
Sanyo PLC-XU73 Multimedia Projector Questions & Answers
I need to replace the
hi,
for replacing the lamp do the fallowing.
1 turn off the projector and disconnect the AC power . allow the projector to cool for at-least 45 minutes.
2. remove the screw at the bottom to oppen the lamp cover.
3. after that remove 2 screws of the lamp and pull out lamp by grasping the handle.
4. replace the lamp with a new one and tighten the 2 screw s back in to position make sure that the lamp is set properly. replace the lamp cover and tighten the screw.
5. connect ac power turn on te projector and go to the menu select lamp counter make it zero
Replacement lamp type number is : POA-LMP90
OK
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Red vertical lines
Try to change your VGA cable if the problem occur your A/V board was deffective.
No way to get simultaneoulsy my videos on the
Most laptops have a Function (Fn) key in an alternate color (blue maybe) from the usual key text color (white usually).
By pressing this key, along with another key that has text of the same (blue) color, perhaps labelled with "LCD/CRT" or a pic of a monitor, or of 2 squares - one single square and one double "square in square", you can toggle between the modes of:
1. Laptop display only,
2. external display only, or
3. Both displays.
Be sure to check your laptop model manual for specific details to make sure this is possible.
Laptop is not being connected
THE PIN CONNECTION MAYBE DIFFERENT IN THE OTHER LABTOPS YOU WOULD HAVE CONTACT THE VENDEER AND CHECK THE PIN OUT FOR THAT PORT AND SEE IF THEY ARE THE SAME.
THE COMPUTER CABLE SPACIST CAN HELP YOU, CABLE CONNECTION, CABLE AMERICA, AND CABLES TO GO.
ROD
Problem with color shift
Hi there
This might be a faulty Mainboard - that will need repair or replacement - and is quite expensive.
First check by using another cable , if the problem still occurs then the above will most probably apply.
How can i download divers for sanyo xu 101 projector
To download drivers for the Sanyo XU 101 projector, you will need to visit the Sanyo support website. Here are the steps:
- Go to the Sanyo support website by typing "Sanyo support" into your search engine and clicking on the first link.
- Once on the Sanyo support website, click on the "Projectors" category.
- Select your projector model, which in this case is the XU 101.
- Click on the "Downloads" tab, where you can find the available drivers and software for your projector.
- Look for the driver that you need and click on the download link.
- Follow the instructions to download and install the driver.
If you have any issues with the download or installation process, you can contact Sanyo customer support for further assistance.
My Sanyo dp42481 pic is upside down and mirrored how do I fix it
If your Sanyo DP42481 picture is upside down and mirrored, you can try adjusting the settings on the TV. You can do this by going to the Picture Settings menu and selecting the "Picture Orientation" option. From there, you can select the "Normal" option to reset the picture orientation. If the problem persists, you may need to contact the manufacturer for assistance.
Sanyo AWD-AQ4000(S) U3 error code
The "U3" error code on a Sanyo AWD-AQ4000(S) air conditioner indicates that there is a problem with the unit's compressor. This could be caused by a variety of issues, such as a faulty compressor, a malfunctioning control board, or a refrigerant leak.
To solve this issue, I recommend the following steps:
- Make sure that the air conditioner is properly plugged in and receiving power.
- Check for any visible damage to the unit, such as bent fins or loose wires.
- Check the air filter and clean or replace it if it is dirty.
- Check the outdoor unit for any visible damage or debris that may be blocking the airflow.
- Check the refrigerant levels and make sure they are at the proper level.
If those does not work, it may be time to check with a professional!
Sanyo PLC-XU305 Projector
Being an old projector and possibly it has an old lamp fitted.
The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red.
Nothing can be done about that except replace the LCD imagers.
As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
