20 Most Recent
GE WCVH6260FWW Questions & Answers
How do I pull up error codes
Follow these steps to enter the service mode on a GE front load washer. 1. Close the door.
2. Clear current cycles by pressing the power button. Make sure the screen is blank before attempting to enter the service mode.
3. Disconnect power to washer for at least 30 seconds.
4. Reconnect the power and within 30 seconds of reconnecting power complete the next step.
5. Press signal -delay start -signal - delay start.
If you successfully enter the washer into the service mode, t01 will be displayed and the door will lock.
Here's a link to the codes:
http://www.appliance-repair-it.com/GE_front_load_washer.html
Good luck with your troubleshooting!
WCVH6260FWW drum sticking
you have an item in between the inner and outer drums if you take the heater unit out you should now be able to see it remove it
