20 Most Recent Sony VPL-VW100 (Ruby) Multimedia Projector Questions & Answers
0answers
CAR Radio in SAFE mode, don't have the code
go on Ebay you can get codes emailed to u for £1 in the uk in less than an hr, prob the same for USA.
7/30/2017 8:38:39 AM • Sony VPL-VW100... • Answered on Jul 30, 2017
0answers
VW Golf TDI - loss of power and smoke from exhaust
Sounds like a piston ring has failed.Do a compression test to be sure its a ring or valve stem seal.
6/17/2017 6:25:31 AM • Sony VPL-VW100... • Answered on Jun 17, 2017
The lamp on my SONY VPL-VW100 projector will not
The lamp ballast board is giving you fits. The lamp socket wires attach to the board so it should be easy to locate.
4/15/2017 4:02:27 AM • Sony VPL-VW100... • Answered on Apr 15, 2017
Nec vt 460 press on button sudenly status light is on
esupport.sony.com
6/17/2014 8:14:59 AM • Sony VPL-VW100... • Answered on Jun 17, 2014
The screen gets darker with
Hello, and thanks for using FixYa.
Sounds like the lamp might have a problem, I would clean out the dust from the machine and see if it improves. Use canned air and a vacuum cleaner to such out the dust if you don't want to take it apart - and avoid warranty if it still has it.
Now how old, how long has the lamp been running?
If it is the first time this projector is being connected to the device it is connected on now, the signal selection might be set wrong. Check usermanual pages 47 for the signal settings and make sure they are correct.
Please get the user manual if you don't have it from here http://www.projectorcentral.com/pdf/projector_manual_3020.pdf
After you have checked the signal settings then on page 66 follow the instructions to clean the dust filters / air filters. You could also Take out the lamp from the unit, clean the machine from dust with vacuumcleaner and compressed air / canned air only. with better airflow the unit will last much longer.
If you have followed the instructions, the picture should have improved. If it has not, how old is the lamp, how many hours has it been used?
10/15/2010 1:08:52 AM • Sony VPL-VW100... • Answered on Oct 15, 2010
Low humming noise on Sony VPLV-W100 Projector.
I think its for exit air fan please check it
8/13/2010 3:52:42 PM • Sony VPL-VW100... • Answered on Aug 13, 2010
When first turning on the projector there is a
According to me you need to replace the projector lamp, Average lamp hours range from 1,500 to 2,000 hours although new lamp technology promises 6,000 hours. The lamp life of different projectors varies. Most projectors use a lamp hour counter to track the number of hours of lamp use.
Check the projector's on-screen menu to determine the number of lamp hours used. After so many hours of use the lamp should be replaced.
Good Luck and have a nice day..
6/7/2010 3:35:42 PM • Sony VPL-VW100... • Answered on Jun 07, 2010
Why is it in black and white and not color?
reset the settings to factory default and swap out the cable. if that doesn't work, you have a processor issue on the main board. it'll need to be replaced..
2/3/2010 6:43:12 PM • Sony VPL-VW100... • Answered on Feb 03, 2010
What is the guarantee?
According to the Sony warranty card you are covered for two years on parts and labor, one year on accessories. We are not a Sony dealer/outlet, and we do not perform repairs of any kind (FixYa.com is strictly an information service). For repairs, contact the manufacturer via their web site (www.sony.com/service) or call 1-800-222-sony.
12/8/2009 5:08:10 PM • Sony VPL-VW100... • Answered on Dec 08, 2009
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
Popular Tags
43 questions posted
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
golf mk 4 drivers side window regulater
  • Office Equipment & Supplies
