20 Most Recent Nokia C202 Questions & Answers
Quiero liberar mi movil
Quiso decir que desea c?digo de desbloqueo de la red? S? significa, que usted puede conseguir el c?digo de desbloqueo de su proveedor de servicio o bien tratar de comprar un c?digo de desbloqueo de uno cualquiera de los proveedor de servicio de desbloqueo en l?nea como SuperUnlockCodes.com Aqu? se puede desbloquear el tel?fono a bajo costo.
12/23/2014 4:04:55 AM • Nokia C202 • Answered on Dec 23, 2014
The touch screen is not working properly
your phone need updation ... update your phone software, if than not work properly than change your mobile touch pad
2/18/2014 3:31:06 PM • Nokia C202 • Answered on Feb 18, 2014
0answers
03.1322
Be the first to answer 6/20/2013 9:29:30 AM • Nokia C202 • Posted on Jun 20, 2013Be the first to answer
Forgot my memorycard password of nokia c202
Pros: No big software or technical support required.Cons: All data from memory card will be lost.The only hurdle which you have to cross is to get a Nokia E-series phone (E63 for sure). Now take out the memory card from your Nokia C2(-02) phone, which had been constantly prompting for a password which you never set. Then replace it with the memory card in Nokia E(-63) series phone. Now, ignore the memory card password prompt on mobile startup after switching on. Go to--> tools-->memory-->options-->format memory card-->(are u sure?? of course I am sure!!),i.e. click yes...........and viola!! your memory card gets formatted. As soon as you see the option for renaming your memory card, start rejoicing......your work is done.(You might look for other options if above solution wont work).
5/26/2013 8:06:26 AM • Nokia C202 • Answered on May 26, 2013
Nokia 2760: How to turn on and the torch (flashlight)?
Nokia 2760 Flip User Guide
ctfassets.net https://assets.ctfassets.net > Nokia_2760_Flip_Onli... PDF TURN ON WI-FI. 1. Press the center key and select Settings >. Network & Connectivity > Wi-Fi. 2. Turn Wi-Fi to On. 3. Select Available networks and the ... 12 pages ..
4/12/2024 11:21:55 PM • Nokia Cell... • Answered 3 days ago
Nokia phone shows 'imei is corrupted'' what can be the problem? pl help.
That could be the result of someone trying to jail break the phone. The IMEI numer is a specific identification number for that specific phone and if changed will render the phone useless.
4/7/2024 5:16:58 PM • Nokia Cell... • Answered on Apr 07, 2024
Nokia phone says 'IMEI is corrupted' after coming from technician who tried to unlock it. The phone is from Australia. I'm in Sri Lanka. Please help.
Question edited for clarity. So the phone was likely stolen in Australia and shipped to Sri Lanka for sale. For the technician to unlock it by playing with the IMEI, it must have been PUK Locked AKA a SIM Lock. To remove a normal customer set PIN Lock, you just do a hard reset which scrubs the phone clean and reloads the operating system with no lock. A PUK Lock can only be removed by the carrier that provided the phone. The technician tried the impossible task of removing an RSA 128 bit encryption lock by playing with the firmware and corrupted it. You have three choices 1. Give it back to the technician and tell him to fix his mistake 2. Send it to Nokia to have the firmware and IMEI reinstalled 3. Throw it away. Have a read of this Fixya Tip I wrote. https://www.fixya.com/support/r26230986-phone_asks_puk_code_ask_another_way ..
4/7/2024 4:53:33 PM • Nokia Cell... • Answered on Apr 07, 2024
Nokia phone got from australia couldnt be unlocked .im from srilanka, its like blacklisted pl help. nokia g21 ta1415
If it is blacklisted, contact Nokia and prove ownership. They may then be able to help.
4/7/2024 8:18:37 AM • Nokia Cell... • Answered on Apr 07, 2024
How to fix a nokia c5 writing sim card not valid
Contact your service provider, they can clear it for you.
3/20/2024 9:53:47 PM • Nokia Cell... • Answered on Mar 20, 2024
2answers
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone. Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
3/20/2024 10:17:39 AM • Nokia Cell... • Answered on Mar 20, 2024
Nokia 1203 imei 353**********58 Security code
Never post IMEI numbers in an open forum like this. It is the unique number that identifies your phone from any other phone in the world. Those with malintent can clone a phone with your IMEI and you magically pay for their calls. This website gets 11 million views a year and the site has an excellent search feature!
How to reset nokia 1203 security code
Ask Me Fast https://www.askmefast.com > How_to_reset_nokia_1203... You can cancel the security code of your Nokia 1203 device by pressing and holding down this buttons: * + 3 + call + Power on. Before the device will reset, ... ..
3/19/2024 4:14:22 PM • Nokia Cell... • Answered on Mar 19, 2024
Nokia 6111 security code
How to do a hard reset on NOKIA 6111?
HardReset.info https://www.hardreset.info > devices > nokia-6111 Swich off the handset. Hard Reset NOKIA 6111; Then press and hold Call button + * button + 3 button + Power button, until you see Nokia logo.
NOKIA 6111 secret codes and hidden features
HardReset.info https://www.hardreset.info > devices > nokia > codes *#7328748263373738# resets security code. Default security code is 12345. *#1471# Last call (Only Vodafone). *#21# Allows you to check the number that "All ...
3/16/2024 1:06:04 AM • Nokia Cell... • Answered on Mar 16, 2024
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity. ..
3/12/2024 2:49:32 AM • Nokia Cell... • Answered on Mar 12, 2024
I have a Nokia mobile phone locked into Tesco, they have supplied me with an unlocking code which appears to be too long. It does not unlock the phone what can I do?
You normally can't do that. The phone is locked to Tesco in the UK, you can only use their service provider in the UK. The long code is a PUK Lock / SIM Lock code and will lock you out when you put in another SIM Card. If you want to use it in Cyprus. you use a roaming package with Tesco. Or you buy a Cyprus phone. https://www.fixya.com/support/r26056685-phone_asking_puk_code ..
3/12/2024 2:41:50 AM • Nokia Cell... • Answered on Mar 12, 2024
Hello I lost my security code mobile phone nokia 5200 plz help. IMEI NO: 35**********3320551048
This phone is an antique from 2006!
How to do a hard reset on NOKIA 5200?
HardReset.info https://www.hardreset.info > devices > nokia-5200 Next confirm Factory reset operation by clicking Call key. Permanently delete data from NOKIA 5200; Done, operation is done you can work properly on device.
Hard Reset for Nokia 5200 - HardReset24.com
hardreset24.com https://hardreset24.com > instruction > hard-reset-for-no... In order to hard reset a Nokia 5200, you should perform the following steps. Remember! Hard reset will delete all the data on your device; pictures, contacts, ...
NOKIA 5200 secret codes and hidden features
HardReset.info https://www.hardreset.info > devices > nokia > codes The whole list of secret codes for your device. Check out how to get access to hidden mode, advanced features and secret options. ..
3/12/2024 2:36:02 AM • Nokia Cell... • Answered on Mar 12, 2024
I have forgotten My Nokia 101 security code
I notice you are Anonymous. Did you 'find' it?
How to do a hard reset on NOKIA 101?
HardReset.info https://www.hardreset.info > devices > nokia > nokia-101 Press Power button until your phone is on. HardReset NOKIA 101 · Then navigate to Menu -> Settings -> Restore Factory Settings. · Now enter your security code. * ... ..
3/10/2024 2:27:48 AM • Nokia Cell... • Answered on Mar 10, 2024
2answers
What APN and Data settings are needed for accessing the internet via data on a Nokia C3 in Canada I have a Nokia C3-00 and had to have anew OS put on it, Thanks
Just the company who bring you the internet services can help you and give you the answer to that question. Call or contact them.
3/9/2024 3:33:20 PM • Nokia Cell... • Answered on Mar 09, 2024
I forgot my security code for nokia 1110 IMEI 3555111/01/565946/6
Contact your service provider if it is the SIM code otherwise if it is the password you use to gain access, either remember it or factory reset your phone.
3/9/2024 8:27:55 AM • Nokia Cell... • Answered on Mar 09, 2024
2answers
I forget my security pin of Nokia RM 1035 imei 355163068343307
Factory reset will return it to factory condition. ALL data will be lost.
3/8/2024 7:06:37 PM • Nokia Cell... • Answered on Mar 08, 2024
2answers
My NOKIA 105 Ss (2023) got blocked. None of the SIM cards are working on it. I have PUK number to unblock it. But how to enter PUK number in this phone? Where to find PUK settings?
The unlocking instruction for Nokia 105 is not very complicated, but you need to remember that you have only 3 tries to enter the codes. If you enter the codes incorrectly more than 3 times, the code counter might get blocked. Follow these 5 steps to make your Nokia 105 network free 1. Turn on the phone without any sim card 2. Enter the following sequence (#pw+unlock code+1#) on your NOKIA 105 just like a phone number* * Characters p, w, + will appear after pressing the *(star) symbol a couple of times 4. Press # at the end to confirm the code 5. Message "SIM restriction OFF" should appear. Your Nokia 105 is now unlocked !!!
2/20/2024 4:13:28 AM • Nokia Cell... • Answered on Feb 20, 2024
Nokia C202 Logo
9 questions posted
Popular Products
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
quiero liberar mi movil
  • Cell Phones
